I need your help.
The Component Manager is empty on JetPack installation.Any box is unable and can’t select any Jetson target entries.
How to finish this installation of JetPack?
PS:The Linux Host belongs to corporate and can’t connect Internet.
Host Platform:
Linux ubuntu 14.04 x64
JetPack 3.1
Internet connection:invalid.
Hi comlc, internet connection is required to properly run JetPack. JetPack will download the packages into the jetpack_downloads directory it creates under where JetPack was run from.
Hi,dusty_nv
Thank you very much for your reply.
I have flashed rootfilesystem to internal eMMc,but no any components on target.
Can I install those components on target by manual installation,such as libcudnn,libopencv4tegra,libvisionworks? I have download those packages on host and target.
If I am facing similar problem, I have downloaded all the package and component manager is still empty. However, the launcher.log file shows that it cannot read my local.cfg
I’m having a similar issue. I’m connected to the Internet through a proxy, which seems correctly configured. My browser works fine, I was also able to ‘wget’ the .deb suggested by linuxdev
But when I launch the “JetPack-L4T-3.2-linux-x64_b196.run” script, I get an error window “The manifest file is broken.” And the components manager is empty. I already tried to remove all files, and re-download the script on nvidia.com, with no luck.
Any idea ?
I have same issue.
I installed ubuntu 16.04 in virtualbox. Use host briged network and DHCP is enabled.
And I can download the dep file, ping work.
Any idea?
