核心板无法启动
抱歉忘記更新. 已經收到module開始測試. 謝謝您
We have a WAR for this issue here that you could try first.
1) Modify log_level to 0
<Linux_for_Tegra>/bootloader/tegra234-mb1-bct-misc-common.dtsi
        ///////// Debug data //////////
        debug {
            uart_instance = <2>;
            wdt_period_secs = <0>;
#ifdef DISABLE_UART_MB1_MB2
            log_level = <0>;
#else
-            log_level = <4>;
+            log_level = <0>;
#endif
2) Re-generate the images/binaries and re-flash the system
The official solution is not clear yet.
Hi~
我们使用两个异常核芯板验证了这个改动, 确实有效果,核芯板能正常启动了。
我们想知道为什么会这样,我们可以在生产环境引入这个改动么?会有什么负面影响么?
这是改动后的串口启动日志:
<break x 002>
<break>
<break>
<0xff><0xe2>
<break>
<0xff><0xfd><0xff><0xe1><0xff><0xe2>hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is da583751bbfe2b7f6e204562d97ff39e
bpmp: combined binary md5 is e941463f35523d12ee540d9bc33bc02f
bpmp: firmware tag is e941463f35523d12ee54-da583751bbf
<0xff><0xe5>[     0.289094] Camera-FW on t234-rce-safe started
<0xff><0xe2>Control register check for CBB_C<0xff><0xe5>TCU early console enabled.
<0xff><0xe2>ENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
Write control check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 0f18000b != actual value: 00000000 address: 13a159c8
Control register check for CBB_CENTRAL_CBB_FIREWALL_MCB_BLF failed, expected value: 80030000 != actual value: 00000000 address: 13a159d0
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
initialized suspend
initialized strap
initialized mce_dbell
<0xff><0xe8><0xff><0xe2>initialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
<0xff><0xe4>I/TC: Physical secure memory base 0x17c040000 size 0x3fc000<0xff><0xe2>initialized uphy
ini<0xff><0xe4>0
<0xff><0xe2>tialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
initialized clk_cal_late
initialized noc_late
initialized cvc
initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/2 have not matching zones 0/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 0/3 have not matching zones 0/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/0 have not matching zones 1/0
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zone list sizes 1/3
WARNING @ [platform/drivers/rm/rm.c]: shared rails 2/3 have not matching zones 1/2
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/0 have not matching zones 2/0
WARNIN<0xff><0xe4><0xff><0xe2>G @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zone list sizes 3/1
WARNING @ [platform/drivers/rm/rm.c]: shared rails 3/2 have not matching zones 2/1
initialized rm
initialized console_late
<0xff><0xe4>I/TC:
<0xff><0xe2>handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable sdmmc4_axicif
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
clk_check_max_rate: pex1_c6_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c7_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c8_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c9_core rate 500000000 > max 250000000
clk_check_max_rate: pex2_c10_core rate 500000000 > max 250000000
clk_check_max_r<0xff><0xe4><0xff><0xe2>ate: pex0_c0_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c1_core rate 500000000 > max 250000000
clk_check_max_rate: pex0_c2_core rate 500<0xff><0xe4>I/TC: Non-secure external DT found
<0xff><0xe2>000000 > max 250000000
clk_check_max_ra<0xff><0xe5>[     0.604012] Camera-FW on t234-rce-safe ready SHA1=c0d3ca5e (crt 12.954 ms,<0xff><0xe2>te: pex0_c3_core rate 500000000 <0xff><0xe5> total boot 328.930 ms)
<0xff><0xe2>> max 250000000
clk_check_max_rate: pex0_c4_core rate 500000000 > max 250000000
clk_check_max_rate: pex1_c5_core rate 500000000 > max 250000000
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
<0xff><0xe8>DCE: FW Boot Done
<0xff><0xe4>I/TC: OP-TEE version: 3.22 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Wed Aug 28 08:55:22 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
<0xff><0xe1>Jetson UEFI firmware (version 6.0-37391689 built on 2024-08-28T08:47:11+00:00)
<0xff><0xe4>I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
I/TC: WARNING: Test UEFI variable auth key is being used !
I/TC: WARNING: UEFI variable protection is not fully enabled !
<0xff><0xe1><0xff><0xe4>E/TC:?? 00 get_rpc_alloc_res:645 RPC allocation failed. Non-secure world result: ret=0xffff0000 ret_origin=0
E/LD:   init_elf:486 sys_open_ta_bin(bc50d971-d4c9-42c4-82cb-343fb7f37896)
E/TC:?? 00 ldelf_init_with_ldelf:131 ldelf failed with res: 0xffff000c
<0xff><0xe1><0x1b>[2J<0x1b>[04D<0x1b>[=3h<0x1b>[2J<0x1b>[09DJetson UEFI firmware (version 6.0-37391689 built on 2024-08-28T08:47:11+00:00)
ESC   to enter Setup.
F11   to enter Boot Manager Menu.
Enter to continue boot.
**  WARNING: Test Key is used.  **
......L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
<0xff><0xe4>I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
<0xff><0xe1>[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[    0.000000] Linux version 5.10.216-tegra (buildbrain@mobile-u64-6429-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 28 01:46:00 PDT 2024
[    0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[    0.000000] OF: fdt:  - 80000000 ,  c0000000
[    0.000000] Machine model: NVIDIA Orin Nano Developer Kit
[    0.000000] efi: EFI v2.70 by EDK II
[    0.000000] efi: RTPROP=0x1661af718 SMBIOS=0xffff0000 SMBIOS 3.0=0x16a1b0000 MEMATTR=0x164932018 ESRT=0x164934298 RNG=0x158590018 MEMRESERVE=0x158f08c18
[    0.000000] random: crng init done
[    0.000000] esrt: Reserving ESRT space from 0x0000000164934298 to 0x00000001649342d0.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000148000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x0000000173ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000fffdffff]
[    0.000000]   node   0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000015b0c8fff]
[    0.000000]   node   0: [mem 0x000000015b0c9000-0x000000015b31bfff]
[    0.000000]   node   0: [mem 0x000000015b31c000-0x00000001687fffff]
[    0.000000]   node   0: [mem 0x0000000168800000-0x000000016a73ffff]
[    0.000000]   node   0: [mem 0x000000016a740000-0x000000016eb0ffff]
[    0.000000]   node   0: [mem 0x000000016eb10000-0x000000016eb1ffff]
[    0.000000]   node   0: [mem 0x0000000172000000-0x0000000173ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000173ffffff]
[    0.000000] On node 0, zone Normal: 224 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 32 pages/cpu s90392 r8192 d32488 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] alternatives: patching kernel code
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 970272
[    0.000000] Kernel command line: root=PARTUUID=6e36dc23-685b-4c83-ba3d-5057f4a432d0 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 nospectre_bhb
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[    0.000000] Memory: 3231884K/3943552K available (18560K kernel code, 3170K rwdata, 7240K rodata, 3968K init, 1415K bss, 449524K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[    0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[    0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[    0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000684] Console: colour dummy device 80x25
[    0.000722] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000730] pid_max: default: 32768 minimum: 301
[    0.000783] LSM: Security Framework initializing
[    0.000805] Yama: becoming mindful.
[    0.000825] SELinux:  Initializing.
[    0.000877] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.000888] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001913] rcu: Hierarchical SRCU implementation.
[    0.001986] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[    0.002366] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0004-p3768-0000-a0.dts
[    0.002371] DTB Build time: Aug 28 2024 01:58:08
[    0.003638] Tegra Revision: A01 SKU: 0xd6 CPU Process: 0 SoC Process: 0
[    0.003807] Remapping and enabling EFI services.
[    0.004661] smp: Bringing up secondary CPUs ...
[    0.033354] Detected PIPT I-cache on CPU1
[    0.033390] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[    0.033413] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[    0.062042] Detected PIPT I-cache on CPU2
[    0.062052] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[    0.062067] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[    0.090665] Detected PIPT I-cache on CPU3
[    0.090674] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[    0.090688] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[    0.121336] Detected PIPT I-cache on CPU4
[    0.121359] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[    0.121388] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[    0.150082] Detected PIPT I-cache on CPU5
[    0.150094] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[    0.150110] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[    0.150176] smp: Brought up 1 node, 6 CPUs
[    0.150189] SMP: Total of 6 processors activated.
[    0.150194] CPU features: detected: Privileged Access Never
[    0.150195] CPU features: detected: LSE atomic instructions
[    0.150197] CPU features: detected: User Access Override
[    0.150199] CPU features: detected: 32-bit EL0 Support
[    0.150201] CPU features: detected: Common not Private translations
[    0.150203] CPU features: detected: RAS Extension Support
[    0.150205] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.150207] CPU features: detected: CRC32 instructions
[    0.150208] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.169693] spectre-bhb mitigation disabled by command line option
[    0.187230] CPU: All CPU(s) started at EL2
[    0.188896] devtmpfs: initialized
[    0.205957] KASLR enabled
[    0.206085] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.206097] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.207778] pinctrl core: initialized pinctrl subsystem
[    0.208292] SMBIOS 3.0.0 present.
[    0.208300] DMI: NVIDIA NVIDIA Orin Nano Developer Kit/Jetson, BIOS 6.0-37391689 08/28/2024
[    0.208580] NET: Registered protocol family 16
[    0.209342] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.209380] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.209414] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.209442] audit: initializing netlink subsys (disabled)
[    0.209516] audit: type=2000 audit(0.208:1): state=initialized audit_enabled=0 res=1
[    0.209760] thermal_sys: Registered thermal governor 'step_wise'
[    0.209763] thermal_sys: Registered thermal governor 'power_allocator'
[    0.209768] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[    0.210701] cpuidle: using governor menu
[    0.210827] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.210899] ASID allocator initialised with 32768 entries
[    0.211041] Serial: AMBA PL011 UART driver
[    0.213011] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[    0.213035] Tegra reboot handler registered.
[    0.233510] mc: mapped MMIO address: 0xffff800010630000 -> 0x2c10000
[    0.233522] mc: mapped MMIO address: 0xffff800010650000 -> 0x2c20000
[    0.233530] mc: mapped MMIO address: 0xffff800010670000 -> 0x2c30000
[    0.233537] mc: mapped MMIO address: 0xffff800010690000 -> 0x2c40000
[    0.233544] mc: mapped MMIO address: 0xffff8000106b0000 -> 0x2c50000
[    0.233550] mc: mapped MMIO address: 0xffff8000106d0000 -> 0x2b80000
[    0.233558] mc: mapped MMIO address: 0xffff8000106f0000 -> 0x2b90000
[    0.233564] mc: mapped MMIO address: 0xffff800010710000 -> 0x2ba0000
[    0.233570] mc: mapped MMIO address: 0xffff800010730000 -> 0x2bb0000
[    0.233576] mc: mapped MMIO address: 0xffff800010750000 -> 0x1700000
[    0.233583] mc: mapped MMIO address: 0xffff800010770000 -> 0x1710000
[    0.233590] mc: mapped MMIO address: 0xffff800010790000 -> 0x1720000
[    0.233603] mc: mapped MMIO address: 0xffff8000107b0000 -> 0x1730000
[    0.233610] mc: mapped MMIO address: 0xffff8000107d0000 -> 0x1740000
[    0.233617] mc: mapped MMIO address: 0xffff8000107f0000 -> 0x1750000
[    0.233624] mc: mapped MMIO address: 0xffff800010810000 -> 0x1760000
[    0.233630] mc: mapped MMIO address: 0xffff800010830000 -> 0x1770000
[    0.233638] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.233659] mc-err: mcerr ops are set to t23x
[    0.234459] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[    1.200304] printk: console [ttyAMA0] enabled
[    1.209209] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    1.215916] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    1.222614] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    1.229313] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    1.237573] ACPI: Interpreter disabled.
[    1.241898] ddr-vddq: supplied by vdd-5v
[    1.245999] ddr-vdd2: supplied by vdd-5v
[    1.250044] vdd-AO-1v2: supplied by vdd-5v
[    1.254269] vdd-3v3: supplied by vdd-5v
[    1.258246] vdd-rtc: supplied by vdd-AO-1v2
[    1.262540] vdd-0v95-uphy: supplied by vdd-AO-1v2
[    1.267377] vdd-0v95-hdmi: supplied by vdd-AO-1v2
[    1.272350] vdd-1v8: supplied by vdd-3v3-sys
[    1.276731] vdd-3v3-AO: supplied by vdd-5v-sys
[    1.281282] vdd-av10-hub: supplied by vdd-5v-sys
[    1.286019] vdd-vbus-a: supplied by vdd-5v-sys
[    1.290572] vdd-vbus-b: supplied by vdd-5v-sys
[    1.295120] vdd-3v3-dp: supplied by vdd-3v3-sys
[    1.299984] iommu: Default domain type: Translated
[    1.304899] eventlib_kernel: keventlib is initialized, test id: 0
[    1.311188] SCSI subsystem initialized
[    1.315013] usbcore: registered new interface driver usbfs
[    1.320513] usbcore: registered new interface driver hub
[    1.325832] usbcore: registered new device driver usb
[    1.331097] mc: Linux media interface: v0.10
[    1.335376] videodev: Linux video capture interface: v2.00
[    1.341040] pps_core: LinuxPPS API ver. 1 registered
[    1.346004] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.355140] PTP clock support registered
[    1.359287] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[    1.366448] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[    1.374142] Registered efivars operations
[    1.378286] FPGA manager framework
[    1.381746] Advanced Linux Sound Architecture Driver Initialized.
[    1.388130] Bluetooth: Core ver 2.22
[    1.391712] NET: Registered protocol family 31
[    1.396154] Bluetooth: HCI device and connection manager initialized
[    1.402508] Bluetooth: HCI socket layer initialized
[    1.407386] Bluetooth: L2CAP socket layer initialized
[    1.412440] Bluetooth: SCO socket layer initialized
[    1.417847] camchar: rtcpu character device driver loaded
[    1.423493] clocksource: Switched to clocksource arch_sys_counter
[    1.617882] VFS: Disk quotas dquot_6.6.0
[    1.621853] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.629062] pnp: PnP ACPI: disabled
[    1.634790] la/ptsa driver initialized.
[    1.638693] NET: Registered protocol family 2
[    1.643156] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.651443] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.659990] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.667944] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.675540] TCP: Hash tables configured (established 32768 bind 32768)
[    1.682122] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.688841] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.696048] NET: Registered protocol family 1
[    1.700593] RPC: Registered named UNIX socket transport module.
[    1.706518] RPC: Registered udp transport module.
[    1.711229] RPC: Registered tcp transport module.
[    1.715933] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.722378] PCI: CLS 0 bytes, default 64
[    1.726400] Trying to unpack rootfs image as initramfs...
[    1.893786] Freeing initrd memory: 9560K
[    1.899904] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.907878] kvm [1]: IPA Size Limit: 48 bits
[    1.912167] kvm [1]: GICv3: no GICV resource entry
[    1.916957] kvm [1]: disabling GICv2 emulation
[    1.921418] kvm [1]: GIC system register CPU interface enabled
[    1.927310] kvm [1]: vgic interrupt IRQ9
[    1.931336] kvm [1]: VHE mode initialized successfully
[    1.937210] Initialise system trusted keyrings
[    1.941750] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    1.950755] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.956912] NFS: Registering the id_resolver key type
[    1.961985] Key type id_resolver registered
[    1.966166] Key type id_legacy registered
[    1.970214] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.976921] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.984329] ntfs: driver 2.1.32 [Flags: R/W].
[    2.003487] NET: Registered protocol family 38
[    2.007933] Key type asymmetric registered
[    2.012027] Asymmetric key parser 'x509' registered
[    2.016922] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[    2.024373] io scheduler mq-deadline registered
[    2.028904] io scheduler kyber registered
[    2.037301] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    2.042904] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    2.048492] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    2.054082] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    2.062436] tegra_dc_assign_hw_data: no matching compatible node
[    2.068463] tegradccommon module_init failed
[    2.072731] tegradc module_init failed
[    2.076759] EINJ: ACPI disabled.
[    2.081840] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    2.088723] tegra-pmc: ### PMC reset source: SYS_RESET_N
[    2.094034] tegra-pmc: ### PMC reset level: L0
[    2.098475] tegra-pmc: ### PMC reset status reg: 0x0
[    2.104849] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    3.507760] printk: console [ttyTCU0] enabled
[    3.512865] arm-smmu 12000000.iommu: probing hardware configuration...
[    3.519559] arm-smmu 12000000.iommu: SMMUv2 with:
[    3.524389] arm-smmu 12000000.iommu: 	stage 1 translation
[    3.529929] arm-smmu 12000000.iommu: 	stage 2 translation
[    3.535461] arm-smmu 12000000.iommu: 	nested translation
[    3.540912] arm-smmu 12000000.iommu: 	stream matching with 128 register groups
[    3.548319] arm-smmu 12000000.iommu: 	128 context banks (0 stage-2 only)
[    3.557518] arm-smmu 12000000.iommu: 	Supported page sizes: 0x00001000
[    3.564215] arm-smmu 12000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.570898] arm-smmu 12000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.578426] arm-smmu 10000000.iommu: probing hardware configuration...
[    3.585119] arm-smmu 10000000.iommu: SMMUv2 with:
[    3.589933] arm-smmu 10000000.iommu: 	stage 1 translation
[    3.595466] arm-smmu 10000000.iommu: 	stage 2 translation
[    3.601000] arm-smmu 10000000.iommu: 	nested translation
[    3.606449] arm-smmu 10000000.iommu: 	stream matching with 128 register groups
[    3.613856] arm-smmu 10000000.iommu: 	128 context banks (0 stage-2 only)
[    3.622995] arm-smmu 10000000.iommu: 	Supported page sizes: 0x00001000
[    3.629691] arm-smmu 10000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.636377] arm-smmu 10000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.643566] arm-smmu 8000000.iommu: probing hardware configuration...
[    3.650173] arm-smmu 8000000.iommu: SMMUv2 with:
[    3.654901] arm-smmu 8000000.iommu: 	stage 1 translation
[    3.660350] arm-smmu 8000000.iommu: 	stage 2 translation
[    3.665799] arm-smmu 8000000.iommu: 	nested translation
[    3.671152] arm-smmu 8000000.iommu: 	stream matching with 128 register groups
[    3.678472] arm-smmu 8000000.iommu: 	128 context banks (0 stage-2 only)
[    3.687525] arm-smmu 8000000.iommu: 	Supported page sizes: 0x00001000
[    3.694126] arm-smmu 8000000.iommu: 	Stage-1: 48-bit VA -> 48-bit IPA
[    3.700730] arm-smmu 8000000.iommu: 	Stage-2: 48-bit IPA -> 48-bit PA
[    3.708036] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[    3.717841] tegra_profiler: version: 1.151, samples/io: 51/30
[    3.723819] tegra_profiler: auth: init
[    3.727977] nvsciipc: loaded module
[    3.733319] tun: Universal TUN/TAP device driver, 1.6
[    3.739026] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    3.746438] hns3: Copyright (c) 2017 Huawei Corporation.
[    3.751917] e1000e: Intel(R) PRO/1000 Network Driver
[    3.757001] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.763088] igb: Intel(R) Gigabit Ethernet Network Driver
[    3.768626] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.774512] PPP generic driver version 2.4.2
[    3.778945] PPP BSD Compression module registered
[    3.783771] PPP Deflate Compression module registered
[    3.788960] PPP MPPE Compression module registered
[    3.793904] usbcore: registered new interface driver r8152
[    3.799538] usbcore: registered new interface driver asix
[    3.805092] usbcore: registered new interface driver ax88179_178a
[    3.811361] usbcore: registered new interface driver cdc_ether
[    3.817370] usbcore: registered new interface driver net1080
[    3.823177] usbcore: registered new interface driver cdc_subset
[    3.829260] usbcore: registered new interface driver zaurus
[    3.834986] usbcore: registered new interface driver cdc_ncm
[    3.840797] usbcore: registered new interface driver aqc111
[    3.846644] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.852995] ohci-pci: OHCI PCI platform driver
[    3.857565] ohci-platform: OHCI generic platform driver
[    3.863291] tegra-xusb 3610000.xhci: Adding to iommu group 0
[    3.869647] usbcore: registered new interface driver uas
[    3.875124] usbcore: registered new interface driver usb-storage
[    3.881444] tegra-xudc 3550000.xudc: Adding to iommu group 1
[    3.887531] mousedev: PS/2 mouse device common for all mice
[    3.893271] usbcore: registered new interface driver xpad
[    3.900748] tegra_rtc c2a0000.rtc: registered as rtc1
[    3.906210] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:21 UTC (21)
[    3.914430] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.920831] i2c /dev entries driver
[    3.924535] tegra-i2c 3160000.i2c: Adding to iommu group 2
[    3.930329] tegra-i2c c240000.i2c: Adding to iommu group 2
[    3.936016] tegra-i2c 3180000.i2c: Adding to iommu group 2
[    3.941692] tegra-i2c 3190000.i2c: Adding to iommu group 2
[    3.947365] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[    3.953044] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[    3.958722] tegra-i2c c250000.i2c: Adding to iommu group 2
[    3.964405] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[    3.973043] pps pps0: new PPS source ktimer
[    3.977336] pps pps0: ktimer PPS source registered
[    3.982247] pps_ldisc: PPS line discipline registered
[    3.988398] device-mapper: uevent: version 1.0.3
[    3.993235] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    4.002953] sdhci: Secure Digital Host Controller Interface driver
[    4.009296] sdhci: Copyright(c) Pierre Ossman
[    4.013770] Synopsys Designware Multimedia Card Interface Driver
[    4.020025] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.026607] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[    4.034573] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[    4.042920] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[    4.048526] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x82
[    4.058587] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[    4.064512] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
<0xff><0xe2>debugfs initialized
<0xff><0xe1>[    5.554216] hid: raw HID events driver (C) Jiri Kosina
[    5.560094] usbcore: registered new interface driver usbhid
[    5.565821] usbhid: USB HID core driver
[    5.570262] tegra-dce d800000.dce: Adding to iommu group 3
[    5.576965] dce: dce_ipc_channel_init:319  Invalid Channel State [0x0] for ch_type [2]
[    5.585611] tegra234-aon c000000.aon: Adding to iommu group 4
[    5.592068] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.601041] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [0]. Ignored...
[    5.601045] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x5]
[    5.602175]  c000000.aon:hsp: probed
[    5.609815] tegra234-aon c000000.aon: init done
[    5.618777] dce: dce_admin_send_cmd_ver:424  version : [0x2] err : [0x0]
[    5.622844] tegra23x-psc e860000.psc: Adding to iommu group 5
[    5.627249] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x1]
[    5.634368] tegra23x-psc e860000.psc: ext_cfg base:0000000048887c46
[    5.639941] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [1] ...
[    5.639946] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    5.639948] dce: dce_admin_setup_clients_ipc:529  Get queue info failed for [2]
[    5.648891] tegra23x-psc e860000.psc: init done
[    5.649080] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 6
[    5.655352] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [1]. Ignored...
[    5.655363] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    5.655369] dce: dce_mailbox_set_full_interrupt:165  Intr bit set multiple times for MB : [0x2]
[    5.655371] dce: dce_admin_setup_clients_ipc:553  Channel Reset Complete for Type [3] ...
[    5.664749] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    5.672527] dce: dce_admin_ipc_handle_signal:90   Spurious signal on channel: [3]. Ignored...
[    5.672529] dce: dce_start_boot_flow:173  DCE_BOOT_DONE
[    5.749487] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[    5.758701] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    5.770156] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[    5.781355] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[    5.793089] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[    5.805696] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[    5.818555] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[    5.831084] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (112)
[    5.837886] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[    5.846519] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=c0d3ca5e4fcb15760fb8525f7a25cfb9878b4139
[    5.859973] t19x_cache tegra-cache: probed
[    5.864407] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[    5.87<0xff><0xe4><0xff><0xe1>4730] optee: probi<0xff><0xe4>I<0xff><0xe1>ng for conduit met<0xff><0xe4>/<0xff><0xe1>hod.
<0xff><0xe4>TC: Reserved shared memory is disabled
<0xff><0xe1>[    5.879332] optee: revision 3.22 (eb8130c7)
[    5.938161] optee: dynamic shared memory is enabled
[    5.947590] optee: initialized driver
[    5.963586] nvpmodel: initialized successfully
[    5.968271] tegra_hv: get_hvd: not initialized yet
[    5.973205] user_ivc_mempool: hypervisor not present
[    5.979093] usbcore: registered new interface driver snd-usb-audio
[    5.986251] u32 classifier
[    5.989039]     input device check on
[    5.992819]     Actions configured
[    5.996490] Initializing XFRM netlink socket
[    6.001419] NET: Registered protocol family 10
[    6.007658] Segment Routing with IPv6
[    6.011468] NET: Registered protocol family 17
[    6.016072] NET: Registered protocol family 15
[    6.020717] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    6.034912] Bluetooth: RFCOMM socket layer initialized
[    6.040234] Bluetooth: RFCOMM ver 1.11
[    6.044147] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    6.050236] Bluetooth: HIDP socket layer initialized
[    6.056433] 9pnet: Installing 9P2000 support
[    6.060890] Key type dns_resolver registered
[    6.066121] registered taskstats version 1
[    6.070350] Loading compiled-in X.509 certificates
[    6.086178] Loaded X.509 cert 'Build time autogenerated kernel key: 8bf422cbdacfe43c83374f4270ed8f21e8dceb0f'
[    6.096847] tegra194-pcie 14100000.pcie: Adding to iommu group 7
[    6.109819] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    6.117063] tegra194-pcie 14160000.pcie: Adding to iommu group 8
[    6.129549] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    6.136469] tegra194-pcie 141e0000.pcie: Adding to iommu group 9
[    6.148657] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    6.155472] tegra194-pcie 140a0000.pcie: Adding to iommu group 10
[    6.167637] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    6.200133] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 11
[    6.210194] host1x 13e40000.host1x: Adding to iommu group 12
[    6.243547] host1x 13e40000.host1x: initialized
[    6.248609] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 13
[    6.256636] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[    6.267630] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 14
[    6.275620] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[    6.286572] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 15
[    6.294568] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[    6.305511] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 16
[    6.313477] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[    6.324427] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 17
[    6.332401] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[    6.343342] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 18
[    6.351304] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[    6.362274] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 19
[    6.370244] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[    6.381222] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 20
[    6.389202] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[    6.400176] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 21
[    6.408146] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[    6.419106] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 22
[    6.427108] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[    6.438063] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 23
[    6.446015] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[    6.456989] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 24
[    6.464948] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[    6.475900] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 25
[    6.483871] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[    6.494845] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 26
[    6.502810] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[    6.513782] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 27
[    6.521748] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[    6.532697] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 28
[    6.540657] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[    6.551663] falcon 15340000.vic: Adding to iommu group 29
[    6.562206] falcon 15340000.vic: initialized
[    6.566978] falcon 15380000.nvjpg: Adding to iommu group 30
[    6.576148] falcon 15380000.nvjpg: initialized
[    6.580868] falcon 15540000.nvjpg1: Adding to iommu group 31
[    6.589749] falcon 15540000.nvjpg1: initialized
[    6.594563] falcon 15a50000.ofa: Adding to iommu group 32
[    6.604119] falcon 15a50000.ofa: initialized
[    6.608688] nvdec 15480000.nvdec: Adding to iommu group 33
[    6.620477] nvdec 15480000.nvdec: initialized
[    6.625115] tsec 15500000.tsec: Adding to iommu group 34
[    6.635222] tsec 15500000.tsec: initialized
[    6.643229] gic 2a41000.agic-controller: GIC IRQ controller registered
[    6.659201] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    6.675225] gpio-397 (camera-control-output-low): hogged as output/low
[    6.681993] gpio-486 (camera-control-output-low): hogged as output/low
[    6.689797] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[    6.697254] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[    6.704252] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    6.710744] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    6.717266] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    6.723545] tegra-pwm 32e0000.pwm: PWM clk can sleep in ops
[    6.732077] tegra194-isp5 14800000.isp: Adding to iommu group 35
[    6.740129] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[    6.749565] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[    6.756025] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.765248] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[    6.774634] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 36
[    6.782738] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 37
[    6.790747] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: Adding to iommu group 36
[    6.798927] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[    6.805995] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: Adding to iommu group 37
[    6.814031] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[    6.821115] scare-pigeon 13e40000.host1x:isp-thi@14b00000: Adding to iommu group 35
[    6.829280] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[    6.836427] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 2
[    6.843600] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[    6.851101] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[    6.857733] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[    6.864485] serial-tegra 3100000.serial: Adding to iommu group 2
[    6.871071] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 17, base_baud = 0) is a TEGRA_UART
[    6.880865] serial-tegra 3130000.serial: Adding to iommu group 2
[    6.887396] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 63, base_baud = 0) is a TEGRA_UART
[    6.897132] serial-tegra 3140000.serial: Adding to iommu group 2
[    6.903733] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 64, base_baud = 0) is a TEGRA_UART
[    6.929541] tegra-xusb 3610000.xhci: Firmware timestamp: 2023-02-10 03:48:10 UTC, Version: 80.05 release
[    6.939295] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.944870] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    6.953536] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[    6.963148] tegra-xusb 3610000.xhci: irq 218, io mem 0x03610000
[    6.969511] tegra-xusb 3610000.xhci: xHCI Host Controller
[    6.975072] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    6.982866] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    6.990513] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    6.999018] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.006454] usb usb1: Product: xHCI Host Controller
[    7.011464] usb usb1: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[    7.017730] usb usb1: SerialNumber: 3610000.xhci
[    7.023800] hub 1-0:1.0: USB hub found
[    7.027714] hub 1-0:1.0: 4 ports detected
[    7.032234] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    7.040743] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.048170] usb usb2: Product: xHCI Host Controller
[    7.053178] usb usb2: Manufacturer: Linux 5.10.216-tegra xhci-hcd
[    7.059451] usb usb2: SerialNumber: 3610000.xhci
[    7.065311] hub 2-0:1.0: USB hub found
[    7.069217] hub 2-0:1.0: 4 ports detected
[    7.095481] i2c i2c-2: Added multiplexed i2c bus 9
[    7.100737] i2c i2c-2: Added multiplexed i2c bus 10
[    7.105771] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    7.112760] tegra23x-oc-event soctherm-oc-event: Finished tegra23x overcurrent event probing
[    7.133315] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1537000 KHz, changing to: 1510400 KHz
[    7.146045] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1490000 KHz, changing to: 1497600 KHz
[    7.157913] tegra194-cpufreq e000000.ccplex: probed with ICC, cl:3
[    7.165619] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[    7.173528] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[    7.180712] tegra194-pcie 14100000.pcie:       IO 0x0030100000..0x00301fffff -> 0x0030100000
[    7.189398] tegra194-pcie 14100000.pcie:      MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[    7.198077] tegra194-pcie 14100000.pcie:      MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[    7.291501] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    7.315496] tegra194-pcie 14100000.pcie: Link up
[    7.322999] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[    7.329826] pci_bus 0001:00: root bus resource [bus 00-ff]
[    7.335467] pci_bus 0001:00: root bus resource [io  0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[    7.345298] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[    7.356151] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[    7.364089] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[    7.370442] pci 0001:00:00.0: PME# supported from D0 D3hot
[    7.381922] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[    7.388262] pci 0001:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    7.394198] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.402676] pci 0001:01:00.0: supports D1 D2
[    7.407075] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    7.419202] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[    7.426633] pci 0001:00:00.0: BAR 13: assigned [io  0x1000-0x1fff]
[    7.433012] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[    7.441020] pci 0001:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    7.447318] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    7.452691] pci 0001:00:00.0:   bridge window [io  0x1000-0x1fff]
[    7.458960] pci 0001:00:00.0:   bridge window [mem 0x20a8000000-0x20a80fffff]
[    7.466368] pci 0001:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    7.475145] pci 0001:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    7.484233] pcieport 0001:00:00.0: Adding to iommu group 7
[    7.490251] pcieport 0001:00:00.0: PME: Signaling with IRQ 55
[    7.496611] pcieport 0001:00:00.0: AER: enabled with IRQ 55
[    7.503414] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[    7.511028] usb 1-2: New USB device found, idVendor=0bda, idProduct=5489, bcdDevice= 1.40
[    7.511844] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[    7.519439] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.519443] usb 1-2: Product: 4-Port USB 2.0 Hub
[    7.526614] tegra194-pcie 14160000.pcie:       IO 0x0036100000..0x00361fffff -> 0x0036100000
[    7.533937] usb 1-2: Manufacturer: Generic
[    7.551621] tegra194-pcie 14160000.pcie:      MEM 0x2428000000..0x242fffffff -> 0x0040000000
[    7.560318] tegra194-pcie 14160000.pcie:      MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[    7.560371] hub 1-2:1.0: USB hub found
[    7.574020] hub 1-2:1.0: 4 ports detected
[    7.612530] usb 2-1: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[    7.660066] usb 2-1: New USB device found, idVendor=0bda, idProduct=0489, bcdDevice= 1.40
[    7.668481] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.675818] usb 2-1: Product: 4-Port USB 3.0 Hub
[    7.680553] usb 2-1: Manufacturer: Generic
[    7.695584] hub 2-1:1.0: USB hub found
[    7.701633] hub 2-1:1.0: 4 ports detected
[    7.779495] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[    7.941336] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[    7.949752] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    7.957092] usb 1-3: Product: Bluetooth Radio
[    7.961558] usb 1-3: Manufacturer: Realtek
[    7.965761] usb 1-3: SerialNumber: 00e04c000001
[    8.676834] tegra194-pcie 14160000.pcie: Phy link never came up
[    8.683046] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[    8.689864] pci_bus 0004:00: root bus resource [bus 00-ff]
[    8.695504] pci_bus 0004:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[    8.705605] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[    8.716428] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[    8.724356] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[    8.730698] pci 0004:00:00.0: PME# supported from D0 D3hot
[    8.746186] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[    8.751586] pci 0004:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.760644] pcieport 0004:00:00.0: Adding to iommu group 8
[    8.766564] pcieport 0004:00:00.0: PME: Signaling with IRQ 57
[    8.773163] pcieport 0004:00:00.0: AER: enabled with IRQ 57
[    8.779233] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[    8.785353] pci 0004:00:00.0: Removing from iommu group 8
[    8.790917] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[    8.798664] tegra194-pcie 141e0000.pcie: Using GICv2m MSI allocator
[    8.806573] tegra194-pcie 141e0000.pcie: host bridge /pcie@141e0000 ranges:
[    8.813750] tegra194-pcie 141e0000.pcie:       IO 0x003e100000..0x003e1fffff -> 0x003e100000
[    8.822439] tegra194-pcie 141e0000.pcie:      MEM 0x3228000000..0x322fffffff -> 0x0040000000
[    8.831117] tegra194-pcie 141e0000.pcie:      MEM 0x2e40000000..0x3227ffffff -> 0x2e40000000
[    8.947709] tegra194-pcie 141e0000.pcie: Link up
[    8.955393] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[    8.962207] pci_bus 0007:00: root bus resource [bus 00-ff]
[    8.967847] pci_bus 0007:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x3e100000-0x3e1fffff])
[    8.977950] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[    8.988775] pci_bus 0007:00: root bus resource [mem 0x2e40000000-0x3227ffffff pref]
[    8.996688] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[    9.002989] pci 0007:00:00.0: PME# supported from D0 D3hot
[    9.013771] pci 0007:01:00.0: [15b7:5015] type 00 class 0x010802
[    9.020108] pci 0007:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    9.028628] pci 0007:01:00.0: 15.752 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x2 link at 0007:00:00.0 (capable of 63.012 Gb/s with 16.0 GT/s PCIe x4 link)
[    9.048814] pci 0007:00:00.0: BAR 14: assigned [mem 0x3228000000-0x32280fffff]
[    9.056238] pci 0007:01:00.0: BAR 0: assigned [mem 0x3228000000-0x3228003fff 64bit]
[    9.064190] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[    9.069559] pci 0007:00:00.0:   bridge window [mem 0x3228000000-0x32280fffff]
[    9.076920] pci 0007:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.085654] pci 0007:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    9.094666] pcieport 0007:00:00.0: Adding to iommu group 9
[    9.100564] pcieport 0007:00:00.0: PME: Signaling with IRQ 59
[    9.107529] pcieport 0007:00:00.0: AER: enabled with IRQ 59
[    9.113633] nvme 0007:01:00.0: Adding to iommu group 9
[    9.119499] nvme nvme0: pci function 0007:01:00.0
[    9.124595] nvme 0007:01:00.0: enabling device (0000 -> 0002)
[    9.125231] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    9.137411] vdd-3v3-sd: supplied by vdd-3v3
[    9.144010] tegra194-isp5 14800000.isp: initialized
[    9.152139] nvme nvme0: allocated 32 MiB host memory buffer.
[    9.152429] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[    9.164600] (NULL device *): fops function table already registered
[    9.172028] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[    9.178921] nvme nvme0: 6/0/0 default/read/poll queues
[    9.179142] tegra194-pcie 140a0000.pcie: Using GICv2m MSI allocator
[    9.191339] irq: IRQ289: trimming hierarchy from :interrupt-controller@f400000-1
[    9.200826]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    9.308744] tegra194-pcie 140a0000.pcie: host bridge /pcie@140a0000 ranges:
[    9.315946] tegra194-pcie 140a0000.pcie:       IO 0x002a100000..0x002a1fffff -> 0x002a100000
[    9.324635] tegra194-pcie 140a0000.pcie:      MEM 0x3528000000..0x352fffffff -> 0x0040000000
[    9.333316] tegra194-pcie 140a0000.pcie:      MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[    9.447708] tegra194-pcie 140a0000.pcie: Link up
[    9.455160] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[    9.461989] pci_bus 0008:00: root bus resource [bus 00-ff]
[    9.467631] pci_bus 0008:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x2a100000-0x2a1fffff])
[    9.477736] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[    9.488563] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[    9.496492] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[    9.502820] pci 0008:00:00.0: PME# supported from D0 D3hot
[    9.514072] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[    9.520394] pci 0008:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    9.526308] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[    9.533412] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[    9.541453] pci 0008:01:00.0: supports D1 D2
[    9.545850] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    9.558050] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[    9.565486] pci 0008:00:00.0: BAR 13: assigned [io  0x300000-0x300fff]
[    9.572214] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[    9.580185] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[    9.588156] pci 0008:01:00.0: BAR 0: assigned [io  0x300000-0x3000ff]
[    9.594807] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[    9.600183] pci 0008:00:00.0:   bridge window [io  0x300000-0x300fff]
[    9.606806] pci 0008:00:00.0:   bridge window [mem 0x3528000000-0x35280fffff]
[    9.614166] pci 0008:00:00.0: Max Payload Size set to  128/ 256 (was  256), Max Read Rq  512
[    9.622911] pci 0008:01:00.0: Max Payload Size set to  128/ 128 (was  128), Max Read Rq  512
[    9.632006] pcieport 0008:00:00.0: Adding to iommu group 10
[    9.638046] pcieport 0008:00:00.0: PME: Signaling with IRQ 61
[    9.645023] pcieport 0008:00:00.0: AER: enabled with IRQ 61
[    9.652598] irq: IRQ291: trimming hierarchy from :pmc@c360000
[    9.658593] irq: IRQ292: trimming hierarchy from :interrupt-controller@f400000-1
[    9.666291] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    9.674222] tegra-se-nvhost 15810000.se: Adding to iommu group 38
[    9.680970] tegra-se-nvhost 15810000.se: initialized
[    9.695317] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    9.701713] tegra-se-nvhost 15820000.se: Adding to iommu group 39
[    9.708279] tegra-se-nvhost 15820000.se: initialized
[    9.714464] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    9.720860] tegra-se-nvhost 15840000.se: Adding to iommu group 40
[    9.727421] tegra-se-nvhost 15840000.se: initialized
[    9.733800] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    9.740756] tegra_actmon d230000.actmon: in actmon_register()...
[    9.747122] tegra_actmon d230000.actmon: bwmgr_disable = 1
[    9.753172] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[    9.761618] hvc_sysfs: hypervisor is not present
[    9.766398] clk: Disabling unused clocks
[    9.807297] ALSA device list:
[    9.810369]   No soundcards found.
[    9.814787] Freeing unused kernel memory: 3968K
[    9.819520] Run /init as init process
[    9.838896] Root device found: PARTUUID=6e36dc23-685b-4c83-ba3d-5057f4a432d0
[   10.130583] EXT4-fs (nvme0n1p1): 4 orphan inodes deleted
[   10.136059] EXT4-fs (nvme0n1p1): recovery complete
[   10.142167] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[   10.155187] Rootfs mounted over PARTUUID=6e36dc23-685b-4c83-ba3d-5057f4a432d0
[   10.169589] Switching from initrd to actual rootfs
[   10.211807] systemd[1]: System time before build time, advancing clock.
[   10.262625] systemd[1]: systemd 245.4-4ubuntu3.23 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[   10.286366] systemd[1]: Detected architecture arm64.
[   10.303670] systemd[1]: Set hostname to <tegra-ubuntu>.
[   10.455747] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   10.468731] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   10.478621] systemd[1]: Created slice system-modprobe.slice.
[   10.499864] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   10.519822] systemd[1]: Created slice User and Session Slice.
[   10.539616] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.563853] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.587589] systemd[1]: Reached target User and Group Name Lookups.
[   10.607532] systemd[1]: Reached target Slices.
[   10.623523] systemd[1]: Reached target Mounting snaps.
[   10.643516] systemd[1]: Reached target Mounted snaps.
[   10.663523] systemd[1]: Reached target Swap.
[   10.679833] systemd[1]: Listening on RPCbind Server Activation Socket.
[   10.699663] systemd[1]: Listening on Syslog Socket.
[   10.719645] systemd[1]: Listening on fsck to fsckd communication Socket.
[   10.743600] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   10.763786] systemd[1]: Listening on Journal Audit Socket.
[   10.783638] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.803666] systemd[1]: Listening on Journal Socket.
[   10.823678] systemd[1]: Listening on udev Control Socket.
[   10.843621] systemd[1]: Listening on udev Kernel Socket.
[   10.864904] systemd[1]: Mounting Huge Pages File System...
[   10.884788] systemd[1]: Mounting POSIX Message Queue File System...
[   10.904652] systemd[1]: Mounting RPC Pipe File System...
[   10.924750] systemd[1]: Mounting Kernel Debug File System...
[   10.944821] systemd[1]: Mounting Kernel Trace File System...
[   10.964996] systemd[1]: Starting Journal Service...
[   10.985048] systemd[1]: Starting Set the console keyboard layout...
[   11.009165] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   11.036988] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   11.059605] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   11.069381] systemd[1]: Starting Load Kernel Module efi_pstore...
[   11.092901] systemd[1]: Starting Load Kernel Module pstore_blk...
[   11.112719] systemd[1]: Starting Load Kernel Module pstore_zone...
[   11.132744] systemd[1]: Starting Load Kernel Module ramoops...
[   11.152723] systemd[1]: Starting NVIDIA specific first-boot udev script...
[   11.176762] systemd[1]: Started Nameserver information manager.
[   11.195732] systemd[1]: Reached target Network (Pre).
[   11.216056] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.225422] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   11.236372] systemd[1]: Starting Load Kernel Modules...
[   11.250004] nvmap_heap_init: nvmap_heap_init: created heap block cache
[   11.257570] nvmap_page_pool_init: Total RAM pages: 876889
[   11.263141] nvmap_page_pool_init: nvmap page pool size: 109611 pages (428 MB)
[   11.270756] nvmap_background_zero_thread: PP zeroing thread starting.
[   11.281146] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.290813] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[   11.309314] systemd[1]: Starting udev Coldplug all Devices...
[   11.321032] nvgpu: 17000000.ga10b          nvgpu_nvhost_syncpt_init:135  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[   11.321032]
[   11.341565] systemd[1]: Started Journal Service.
[   11.644126] systemd-journald[236]: Received client request to flush runtime journal.
[   12.281236] nvidia: loading out-of-tree module taints kernel.
[   12.334835] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.374004] imx219 9-0010: board setup failed
[   12.380292] imx219: probe of 9-0010 failed with error -121
[   12.412570] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[   12.471289] imx219 10-0010: board setup failed
[   12.495851] imx219: probe of 10-0010 failed with error -121
[   13.209634] using random self ethernet address
[   13.215126] using random host ethernet address
[   13.397784] using random self ethernet address
[   13.402372] using random host ethernet address
Ubuntu 20.04.6 LTS tegra-ubuntu ttyTCU0
tegra-ubuntu login: poincare (automatic login)
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.10.216-tegra aarch64)
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/pro
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
Expanded Security Maintenance for Infrastructure is not enabled.
43 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
Enable ESM Infra to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
Last login: Thu Jan  1 00:00:35 UTC 1970 on ttyAMA0
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
poincare@tegra-ubuntu:~$
可以看到,核芯板已正常启动,但会在
这卡几秒。
We are still checking the root cause. it is okay to add this to your product. The only side effect is just the boot up log might be missing.
This issue is fixed. Please check this post for the final solution.
