I’ve had my Jetson Nano for a few years now and I recently wanted to do a little bit more with it so I bought a new case, the case required the rear IO pins that the B01 has, I ended up buying the Waveshare JETSON-NANO-DEV-KIT And I can’t get anything to work. It works on the original baseboard but no output on the new one, after doing some research I’m starting to think it requires the EMMC version, it has a micro sd card slot on the baseboard and there website says that you can only use it when the EMMC is flashed properly, anyone have any ideas?
You would need an Ubuntu18.04 PC, install NVIDIA SDKM and reflash your Jetson by JetPack.
See also First use of Jetson Nano doesnt boot - Jetson & Embedded Systems / Jetson Nano - NVIDIA Developer Forums
