I’ve tried with both 2022.1.1 and 2022.1.0 to start in VR by using ./isaac-sim.xr.steamvr.sh.
However in both cases isaac sim crashes. I’ve tried with the simulation running and not and different exemple scene but always the same result. I’ve also tried with driver 470, 510 and 520 and all lead to crash.
What could be the issue ?
Attached is one of the many crash report. I am also unable to get the minidump to save to disk so maybe this could provide more information
crash_2022-11-07_18-08-21_40414.txt (4.2 KB)
Also here is the backtrace from the log
2022-11-08 15:42:50 [308,037ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 98057 backtrace follows:
2022-11-08 15:42:51 [308,391ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libcarb.events.plugin.so!std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()+0xde4 (??:?)
2022-11-08 15:42:51 [308,720ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libcarb.assets.plugin.so!std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&, unsigned long, unsigned long)+0x8e54 (??:?)
2022-11-08 15:42:51 [309,095ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libcarb.datasource-file.plugin.so!std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()+0x424 (??:?)
2022-11-08 15:42:52 [309,451ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libgpu.foundation.plugin.so!std::fill(std::_Bit_iterator, std::_Bit_iterator, bool const&)+0x374 (??:?)
2022-11-08 15:42:52 [309,809ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.datasource-omniclient.plugin.so!std::_V2::condition_variable_any::~condition_variable_any()+0x1044 (??:?)
2022-11-08 15:42:53 [310,169ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libomni.kit.renderer.plugin.so!std::__future_base::_Result<carb::datasource::Connection*>::_M_destroy()+0x3674 (??:?)
2022-11-08 15:42:53 [310,558ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: librtx.materialdb.plugin.so!std::mutex::lock()+0x224 (??:?)
2022-11-08 15:42:53 [310,915ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
2022-11-08 15:42:54 [311,257ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: vrclient.so!LfMutexUnlockRobust(LfMutex*)+0x38 (??:?)
2022-11-08 15:42:54 [311,595ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: vrclient.so!CSyncLockThread::Run()+0x9a (??:?)
2022-11-08 15:42:54 [311,923ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: vrclient.so!SteamThreadTools::CThread::ThreadProc(void*)+0xb9 (??:?)
2022-11-08 15:42:55 [312,323ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libpthread.so.0!start_thread+0xd9 (/build/glibc-SzIz7B/glibc-2.31/nptl/pthread_create.c:478 (discriminator 6))
And here is the full log
kit_20221108_154654.log (1.1 MB)
