Software Version
DRIVE OS 6.0.10.0
[*] DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (940-63710-0010-300)
other
SDK Manager Version
2.1.0
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
We are currently working with Nvidia Drive AGX Orin, along with the Vehicle Accessory Kit. I have a DrivBy Wire system integrated into my vehicle. The DBW System itself has a list of DBC files, like the Drive AGX unit. I am looking to control the Vehicle(along with the DBW system fitted in it) through the Drive unit.
I believe this would require CAN Signal mapping. Is there a way to do this CAN Signal mapping in the Drive Unit itself? If so, how do we do it?
Thanks in advance,
Chintan L. Patel
In addition, We are NOT using Dataspeed drive-by-wire (DbW) system. We are utilizing Level-five supplies Sygnal Drive-by-wire Kit.
Dear @chintan.patel2,
Do you want to use this DbW system with DW ?
Hello @SivaRamaKrishnaNV ,
Yes, I want to utilize Sygnal Drive-by -Wire kit with the Nvidia DriveWorks.
Thank You
Could you elaborate on what kind of CAN signal mapping are you referring here?
Dear @SivaRamaKrishnaNV ,
Yes sure,
The Sygnal Drive by Wire system has a set of DBC files of it own, like that of the Nvidia AGX Orin. For Example, if we take into consideration the CAN frame for Throttle Command in both the Drive-by-Wire kit and that of Drive AGX.
Drive-by-Wire kit
‘‘BO_ 2147483794 OSCC_THROTTLE_COMMAND: 8 UserApplication
SG_ throttle_command : 16|32@1- (1,0) [0|1] “” SygnalMCM
SG_ magic2 : 8|8@1+ (1,0) [204|204] “” SygnalMCM
SG_ magic1 : 0|8@1+ (1,0) [5|5] “” SygnalMCM’’
‘‘BO_ 10 Throttle_Cmd: 5 Vector__XXX
SG_ ThrottlePedalCmd : 8|15@1+ (0.01,0) [0|0] “Per” Vector__XXX
SG_ ThrottleClearFaultCmd : 4|1@1+ (1,0) [0|0] “” Vector__XXX
SG_ ThrottlePedalCmdValid : 3|1@1+ (1,0) [0|0] “” Vector__XXX’’
So, as we can see the name which is obvious is different, but also the size, start bit in the CAN signal is different. So I believe i will have to map the signals to each other, as in when i call a Throttle command(in terms of function), the command for throttle will be called on my drive by wire system. Am I right in saying this?
Thank you,
Chintan
Any updates for me regarding the ongoing query?
Thank you,
Chintan.
Hello @SivaRamaKrishnaNV,
Thank you,
Chintan.
I have .dbc files of my SYGNAL Drive by Wire kit, would that be interpreted by the can message Interpreter?
Also, shall I send you a private message along with the dbc file?
Kind regards,
Chintan L.
Dear @chintan.patel2 ,
Did you try CAN message interpreter sample with your DBC?
