Hello, I have a vehicle that drives on an environment in isaac sim. After a certain period of traversing normally, it randomly appears to get “stuck” where the wheels are turning, with nothing in its path (checked and viewed mesh of entire world), but it does not move. The ground has a physics property applied giving it dynamic friction, and currently has a triangle mesh (have tried SDF as well), while the vehicle wheels currently have bounding sphere colliders (have tried triangle as well). The wheels are set up with revolute joints, and control is administed through setting the “target velocity” of the revolute joints. When the vehicle appears to get stuck, these are non-zero numbers implying it is still trying to move forward. Please let me know if you have any ideas on how to fix this.
can you please send a me a repro for the issue? Not sure out of the box what the problem could be, did you try to enable physics debug visualization? You can enable it in Window->Simulation->Physics debug. There are PhysX SDK debug visualization toggles.
Regards,
Ales
Related topics
| Vehicle wheels spinning in place / chassis jitter with identical snippet code (PhysX 3.3.3) | 1 | 1029 | July 28, 2015 | |
| Isaac Sim Physic Vehicle issue help. Vehicle unable to move! | 1 | 461 | May 9, 2024 | |
| Vehicle setted up correctly but not moving | 1 | 731 | January 26, 2018 | |
| Isaac Sim Freezes on URDF with 690 Joints (Mecanum Wheels Belt) | 8 | 367 | September 30, 2025 | |
| PhysX 3.3 vehicle problem | 16 | 5606 | February 9, 2015 | |
| Mecanum wheels simulation not stable | 2 | 371 | December 16, 2025 | |
| Friction cannot be updated in real-time, resulting in incorre,Friction only applies to the current startup time | 6 | 475 | May 5, 2025 | |
| Bringing my robot into Isaac Sim | 2 | 289 | July 1, 2024 | |
| PhysX 3.2.2: Vehicle.. wobbles around and moves uncontrolled | 4 | 1776 | December 19, 2012 | |
| PhysX 3.2 vehicle wheels 'fall out' and rotate on the wrong axis | 15 | 3933 | March 28, 2013 |
