When I use the SDK manager to flash the Jetson agx orin 64 dev kit
When I use the SDK manager to flash the Jetson agx orin 64 dev kit I met error as BELOW: Cannot connect to the device via SSH.Check the user name and password
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Is this really a valid IP?
I don’t know what you are doing.
that IP belongs to the jetson agx orin.
I have successfully flashed the system with the new OS, however, I am unable to continue the following step to install the SDK components.
I have tried re-flashing in automatic and manual mode to no avail.
The ipv4 is set to the default 192.168.55.1.
after it said default ip is not available i set the above ip thinking that may be this will work
Then you should select Ethernet as the connection type, not USB.
Make sure you are able to ping/SSH into this IP on your host PC.
dont know how to ping/ssh into this ip on my pc
It’s nothing different from a normal ping/SSH.
I don’t know what you don’t get.
Or you can just do
sudo apt update
sudo apt install nvidia-jetpack
on the device.
SDK Manager is not really requied now.
ok will try this
