yoowon0
February 20, 2019, 12:42am
1
Hi, I just get the new Xavier platform.
I am trying initial settings on the board following the ‘JetsonHacks’ channel on YouTube as below link.
(JetPack 4.1 - NVIDIA Jetson AGX Xavier - YouTube )
However, I cannot see any package list during the JetPack installation process same with 3min 43sec. in the above YouTube video.
I tried both on Ubuntu 16.04LTS and 18.04LTS but same results.
(The version of JetPack is 4.1.1. and of course the hardware linkage was setup.)
The JetPack.log file describes as follows:
02-20 09:28:39.6 N: GoogleAnalytics disabled
02-20 09:28:39.7 E: fopen failed with file local.db, errno = 2
Please help somebody who know this problem.
Thank you.
FYI, JetPack downloads a manifest of packages and software each time it runs. If it can’t download the manifest, then the step you are looking at remains blank. Are you behind a firewall or proxy?
yoowon0
February 21, 2019, 7:41am
4
Thanks @WayneWWW and @linuxdev .
I just figured out why did not worked.
It’s just because of the proxy settings.
Of course, I had set my Linux PC the proxy but I should have set one more thing to run JetPack 4.1.1.
https://devtalk.nvidia.com/default/topic/1039139/jetson-tx1/jetpack-3-3-l4t-3-3-linux-x64-installation/post/5285722/#5285722
The above post helped my case.
I could run the JetPack executing by
https_proxy=http://username :password@proxy_ip:proxy_port ./JetPack-L4T-4.1.1-linux-x64_b57.run
Do not confuse that the first one is ‘https’ not ‘http’ and the second one is ‘http’ not ‘https’.
