Access to APT repository error, in terminal works fine
Hi all,
I tried to install jetPack 4.5.1 and the get the error in the image, if I try the same command in the terminal it works great.
What am I supposed to do?
Thank you.
hello AndreiNvidia,
it looks like the dependency check failure, does issue persist after $ sudo apt-get update?
thanks
Hello JerryChang,
unfortunatly the issue persist after sudo apt-get update
I didn’t expect the prompt response, thanks
I got a more detailed report, this was generated by checking “Download now. Install later” in Step 02
Blockquote
15:23:20 INFO: Drivers for Jetson - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 to /home/jua1clj/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.5.1_aarch64.tbz2
15:23:21 ERROR: Drivers for Jetson - target_image: DevZone get download url failed: HTTPError: Response code 401 (Unauthorized).
15:23:21 ERROR: Drivers for Jetson - target_image: Download ‘Drivers for Jetson’ failure
15:23:21 ERROR: Drivers for Jetson - target_image: download failed
15:23:21 : Drivers for Jetson - target_image: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 failed, retrying 1…
15:23:21 INFO: Drivers for Jetson - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 to /home/jua1clj/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.5.1_aarch64.tbz2
15:23:22 ERROR: Drivers for Jetson - target_image: DevZone get download url failed: HTTPError: Response code 401 (Unauthorized).
15:23:22 ERROR: Drivers for Jetson - target_image: Download ‘Drivers for Jetson’ failure
15:23:22 ERROR: Drivers for Jetson - target_image: download failed
15:23:22 : Drivers for Jetson - target_image: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 failed, retrying 2…
15:23:23 INFO: Drivers for Jetson - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 to /home/jua1clj/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.5.1_aarch64.tbz2
15:23:23 ERROR: Drivers for Jetson - target_image: DevZone get download url failed: HTTPError: Response code 401 (Unauthorized).
15:23:23 ERROR: Drivers for Jetson - target_image: Download ‘Drivers for Jetson’ failure
15:23:23 ERROR: Drivers for Jetson - target_image: download failed
15:24:44 INFO: Drivers for Jetson - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 to /home/jua1clj/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.5.1_aarch64.tbz2
15:24:44 ERROR: Drivers for Jetson - target_image: The .mtd file is corrupt. Start a new download.
15:24:44 ERROR: Drivers for Jetson - target_image: Download ‘Drivers for Jetson’ failure
15:24:44 ERROR: Drivers for Jetson - target_image: download failed
15:24:44 : Drivers for Jetson - target_image: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 failed, retrying 1…
15:24:45 INFO: Drivers for Jetson - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 to /home/jua1clj/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.5.1_aarch64.tbz2
15:24:45 ERROR: Drivers for Jetson - target_image: DevZone get download url failed: HTTPError: Response code 401 (Unauthorized).
15:24:45 ERROR: Drivers for Jetson - target_image: Download ‘Drivers for Jetson’ failure
15:24:45 ERROR: Drivers for Jetson - target_image: download failed
15:24:45 : Drivers for Jetson - target_image: download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 failed, retrying 2…
15:24:46 INFO: Drivers for Jetson - target_image: start to download https://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.5.1/JETPACK_451_b17/T194/Jetson_Linux_R32.5.1_aarch64.tbz2 to /home/jua1clj/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R32.5.1_aarch64.tbz2
15:24:46 ERROR: Drivers for Jetson - target_image: DevZone get download url failed: HTTPError: Response code 401 (Unauthorized).
15:24:46 ERROR: Drivers for Jetson - target_image: Download ‘Drivers for Jetson’ failure
15:24:46 ERROR: Drivers for Jetson - target_image: download failed
Blockquote
When you first run SDK Manager there is a login option. The default is for partners, which is different than for developing on the Jetsons. It isn’t obvious, but you can change to select the correct dev program instead of partners. Were you using the default partners login? Then it would fail and not be authorized. Otherwise, if using the correct dev login, then there is probably a web error.
Note that from a browser which is already logged in to here:
https://forums.developer.nvidia.com/c/agx-autonomous-machines/jetson-embedded-systems/70
…I can then go here and it allows downloading that file:
Can you log in manually via a browser to the first URL, and then see what happens if you enter the second URL? If you were to instead use something like wget on that second URL, which does not share login with the browser, then it would be expected to get a 401 authorization error.
So for login I’m using the dev program not the partner.
I logged in manually via a browser to the first URL and after I entered the second URL it started downloading the file.
wget on the second URL returns the expected 401 authorization error.
So it seems that the download outside of the sdkmanager is working.
This is correct. wget fails because it hasn’t authenticated with the dev program password. The regular browser works because of the password. SDKM actually uses a separate web browser to perform the authentication, and then the authentication is shared with SDKM. If JetPack/SDKM fails to use the external browser, or if the external browser fails to share authentication with SDKM, then SDKM will also fail in the same manner as wget fails. An example of a possible source of issues might be some sort of javascript blocker on the browser which SDKM uses.
hello AndreiNvidia,
please check the system requirements.
you should also refer to NVIDIA SDK Manager User Guide for more details.
thanks
