Is there a possibility to adjust the colours in the DistanceToCamera or DistanceToImagePlane synthetic data generator? Because right now it is dark blue for the object on a slightly brighter blue for the background, so it is really hard to see anything.
Thank you
Hi there,
DistanceToCamera or DistanceToImagePlane return a 2d array of np.float32
using 1 channel, and do not have any parameterization properties.
You can however modify the data either by using a custom writer or by postprocessing the saved data. For example the kitti writer (omni/replicator/core/scripts/writers_default/kitti.py -> _write_distance_to_camera
) saves the data as np.uint16
Or accessing the annotator data directly using get_data().
