Hello, We have some code at startup that checks the USB ports for an Arduino. However that code is running into an error. In an effort to debug/troubleshoot the jetson we are running into an issue where the jetson does not recognize the mouse or the keyboard, no lights turn on on either device. Using a multimeter we can confirm that both ports are still outputting 5v through vcc and gnd. So the jetson is not communicating with anything. We believe the code is locking up the usb ports to only open communication. So my question is the following: how can we either, avoid the startup code, or create a bootable drive/access something similar to BIOS, without the use of a keyboard or mouse.
DaneLLL
3
The board is from Arduino and please contact the vendor to get further help.
Related topics
| Jetson TX2 Failing to Recognize USB-A Connections | 5 | 779 | February 21, 2022 | |
| Jetson TX2 login unresponsive to keyboard and mouse | 6 | 776 | June 20, 2021 | |
| Jetson TX2 - USB Hub problem | 5 | 1030 | July 18, 2020 | |
| Jetson TX2 keyboard issue when using USB hub | 3 | 666 | September 29, 2020 | |
| Jetson Xavier NX USB port can't work | 5 | 1015 | August 21, 2022 | |
| JETSON AGX XAVIER USB2.0 mouse/keyboard not recognized | 2 | 1041 | October 13, 2021 | |
| Jetson TX2 installed JetPack 3.0 USB Can not work | 2 | 1311 | July 7, 2017 | |
| USB port not working on Orbitty Carrier board Jetson TX2 | 5 | 3231 | May 1, 2019 | |
| L4T 32.7.1 USB startup failed | 5 | 496 | July 21, 2022 | |
| The USB mouse doesn't work on my Jetson TX2's USB port, but the USB mass storage does. | 12 | 1170 | August 26, 2019 |
