I would like to start using Nucleus for collaboration purposes, but want to test it out locally before setting it up via a server or cloud. When trying to launch the Nucleus Compose Stack with my own IP adress, the nucleus navigator won’t run. I would appriciate any help on how to launch the Nucleus Compose Stack locally!
Best regards, Chris
We have installation steps here
Planning Your Installation — Omniverse Nucleus
but the issue you’re having is not clear enough. Are you following the requirements?
What OS are you attempting to install on?
What errors are you seeing?
I get the following error: Error response from daemon: ports are not available: exposing port TCP 0.0.0.0:8080 → 127.0.0.1:0: listen tcp 0.0.0.0:8080
What would be the easiest way to change the port?
I found it, for anyone with the same problem: You can change the port in the nucleus-stack.env under the WEB-PORT variable.
Great, I am glad you found your solution !
