Hi Jerry:
Thanks. I will check with our hardware engineer. By the way, the dts description with spi interface for tpm2.0 module is correct or not? Do you have any reference code?
Add “nvidia,clock-always-on;” description in dts file. The system got /dev/spidev0.0, but the tpm module can’t work too. Do you have any suggestion about this? Thanks!
After doing some modification, I got the message with “dmesg | grep spi”
user@user-desktop:~/spi-tools$ dmesg | grep spi
[ 0.984506] iommu: Adding device 3210000.spi to group 12
[ 0.985027] iommu: Adding device c260000.spi to group 13
[ 2.225579] spi-tegra114 3210000.spi: Prod settings list not initialized
[ 2.226316] spi-tegra114 3210000.spi: prod settings failed with error -22
[ 2.226751] spi-tegra114 3210000.spi: registered master spi0
[ 2.226943] spi spi0.0: setup 8 bpw, ~cpol, ~cpha, 5000000Hz
[ 2.226951] spi spi0.0: child node 'controller-data' not found
[ 2.226999] spi spi0.0: setup mode 0, 8 bits/w, 5000000 Hz max --> 0
[ 2.227211] spi-tegra114 3210000.spi: registered child spi0.0
[ 2.227236] spi spi0.1: setup 8 bpw, ~cpol, ~cpha, 33000000Hz
[ 2.227243] spi spi0.1: child node 'controller-data' not found
[ 2.227258] spi spi0.1: setup mode 0, 8 bits/w, 33000000 Hz max --> 0
[ 2.227447] spi-tegra114 3210000.spi: registered child spi0.1
[ 2.227561] spi-tegra114 c260000.spi: Prod settings list not initialized
[ 2.228252] spi-tegra114 c260000.spi: prod settings failed with error -22
[ 2.228703] spi-tegra114 c260000.spi: registered master spi1
[ 6.719483] spi-tegra114 3210000.spi: Setting clk_src pll_p
[ 6.719895] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.719996] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.736841] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.736940] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.752432] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.752738] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.768432] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.768700] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.784982] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.785710] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.800456] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.800551] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.816481] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.817353] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.833176] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.833458] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.848389] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.850867] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.864418] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.864500] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.880399] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.880484] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.896409] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.896501] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.916400] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.916756] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.932636] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.933081] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.948467] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.948557] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.964502] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.964608] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.980485] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.980588] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 6.996457] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 6.996556] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.012414] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.012503] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.028423] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.028493] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.044833] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.044920] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.060442] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.060537] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.076424] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.076512] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.092423] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.092531] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.108414] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.108506] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.124449] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.124547] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.140408] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.140497] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.156393] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.156478] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.172443] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.172549] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.188789] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.188903] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.204884] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.204992] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.220701] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.220822] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.240461] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.240569] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.256420] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.256511] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.272779] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.272885] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.292761] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.292844] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.308421] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.308519] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.324438] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.324554] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.340440] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.340511] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.356426] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.356550] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.372420] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.372487] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.388414] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.388477] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.404425] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.404523] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.420425] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.420493] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.436407] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.436490] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.456413] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.456483] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.472401] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.472469] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01027
[ 7.472543] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.472605] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e00827
[ 7.472655] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.472716] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01007
[ 7.472766] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e01827
[ 7.472815] spi-tegra114 3210000.spi: The def 0x47d08000 and written 0x43e008
It seems the system try to enable the device, but something went wrong. Is there any suggestion about this? Thanks.
Hi kayccc:
We have add “nvidia,cs-setup-clk-count” & “nvidia,cs-hold-clk-count”, and both values were set to “0x7f”, but the tpm module still can’t work. Are there any detail description about these two properties?
