2023-09-12 14:55:21 [Warning] [gpu.foundation.plugin] Raytracing is not supported on GPU: 1. Skipping this device.
2023-09-12 14:55:21 [Warning] [omni.ext._impl.internal] There is already a module ‘gym’ in 'c:\users\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\python\lib\site-packages\gym_init.py’. Can’t import another module with the same name in public space from ‘c:\users\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.ml_archive\pip_prebundle’.
2023-09-12 14:55:21 [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
2023-09-12 14:55:21 [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
2023-09-12 14:55:21 [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
2023-09-12 14:55:21 [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
2023-09-12 14:55:21 [Warning] [omni.ext.plugin] [ext: omni.kit.importer.cad-0.3.4] Native plugin search dir contains several files: c:/users/appdata/local/ov/pkg/isaac_sim-2022.2.1/extscache/omni.kit.importer.cad-0.3.4+wx64.r.cp37/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
2023-09-12 14:55:21 [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] ‘c:/users/appdata/local/ov/pkg/isaac_sim-2022.2.1/extscache/omni.kit.scripting-104.2.2+104.2.wx64.r.cp37/bin’ in ‘[[native.plugin]]’ was not found.
2023-09-12 15:21:20 [Warning] [omni.kit.browser.folder.core.models.folder_browser_model] Do not load cache for Animation/Anim Graph because url changed:
Hi @ryan910511 - These warnings are generally not critical and do not prevent Isaac Sim from running correctly.
