I feel like I am missing something. I plugged in a TX (which has already been flashed) into the J120 board, and go to power it up. Watching on the power supply there is a little jump from 7mah to 14 then back to 7 and it stays that way. The green light turns on and then flashes. I tried powering on and off several times. I tried applying power to solder points and saw no difference.
What I am missing?
I tried pushing the power button, it sometimes jumps a bit to mah of draw, same with reset. I feel like the board is not sending the right signal to the TX 2 to turn on? Bad board maybe? Maybe it is that it was flashed for an Orbitty Carrier board before?
