Hey, I remember I have seen a video how to make a simple animated water surface.
Like this:
here is also some more:
I want to use this water in Nvidia free asset Bwronstone, there is a water pool in large park.
Like this:
Hello @pekka.varis! The development team is working on water samples in for our Showroom app.
The development team informed me that the swimming pool demo has not been released yet due to some technical limitations with the water simulation physics. We do have several demos planned for release in the very near future, that one included!
(From this post: Omniverse Showroom Dip Pool Demo Availability)
Thanks Wendy!
Meanwhile - if anybody have any idea how to do just a super simple slowly moving water surface please let us know?
Do you want to physical water? Or would animating normals be okay?
Water Shader + Action Graph will do it.
Requirements:
Steps:
Optional:
Here is a video of the process. Only took 2 minutes.
Work out of the box! Best solution ever, there is even the displacement of the underwater elements :)
Could you advise where you obtained the water material with phase input?
Much Obliged
If your question was for me Eric, I just followed the video above and made it manually from scratch.
Any water material in the Material Assets should have that parameter. Check the video I posted.
-Eric
ahh i found them under vMaterials! Thanks Eric :)
This is another way. I see it has been solved, this is an easy way to me.
Here is a method without Action Graph (because I don’t know how to use that).
How to Animate Water
Hey this is a good alt way to do this, and combined they give even more power to shape the water stream direction…
