The jetson is not powering on or even being detected
We have swapped the orin nx carrier board but still the light is not turning on. Also, verified if the carrier board is getting voltage.
In Nvidia SDK Manager the jetson is not being detected with both the carrier boards.
Tried flashing the SSD with Force recovery but not working because it is not getting detected.
What could be the issue and how to solve it?
Hello @founders5,
Have you tried connecting to the board through UART and see if it shows some logs while its connected to the power ?
If you tried multiple carrier boards and you are only experiencing the issue with only that specific SOM, it might be a HW damage issue.
regards,
Andrew
Embedded Software Engineer
ContactUs: support@proventusnova.com
www.proventusnova.com
Since I didnt have the UART to USB cable, I tried connecting the jetson to Arduino over UART, and tried serial dump but nothing.
Buy one cable to dump the log.
I have tried but no luck. I have bought another jetson orin nx module. Does it mean I need to reflash the jetpack or can I use old ssd to run it. Also, can I retrive the old ssd data?
Always reflash with new jetpack when you are checking such issue…
ok. Is there a way to retrieve the old ssd data?
You could move the SSD to another device, mount it and get the data.
