Using ROS2 launch file to simulate on isaac sim
Hello. I have a launch file of a mobile base which I did using ROS2 humble diff_drive_controller. I am wondering whether I can use this file to simulate the movement on isaac sim.
Hi @anu_c
Yes you can simulate, but on Isaac Sim, you need to build on your simulated robot a controller, please follow the Isaac Sim documentation:
Best,
Raffaello
thank you!. I will check these out and get back if any issue.
