Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
my goal is to connect an Ouster OS1 lidar to the DRIVE AGX Pegasus with an ethernet cable and to execute the ./sample_lidar_replay sample with live data from the lidar. However, I have some questions:
1.) On which port do I have to connect the lidar via ethernet to the Pegasus?
2.) How can I obtain the IP of the lidar?
Thank you in advance for answering the two questions above.
thank you very much for your reply. I will update to DriveWorks 3.5.
Yes, the screenshot states that the Ouster OS1 is compatible with the Pegasus. On which port should it then be connected to the Pegasus to work proberly? Can I connect the lidar via an ethernet cable to the ethernet dongle (E3579)? Or should it be connected to the 10GbE RJ45 connectors?
I believe it should be via an ethernet cable to the ethernet dongle (E3579).
But I have no heads-on experience of this so you better follow the guidance to contact the vendor to get efficient support.
