DeepStream SDK FAQ
17.[DeepStream_dGPU_App] Using OpenCV to run deepstream pipeline
Sometimes the gstreamer pipeline in opencv will fail. Please refer to the following topic to resolve this problem.
How to compile OpenCV with Gstreamer [Ubuntu&Windows] | by Galaktyk 01 | Medium
18. Open model deployment on DeepStream (Thanks for the sharing!)
Yolo2/3/4/5/OR : Improved DeepStream for YOLO models (Thanks @marcoslucianops )
YoloV4 : GitHub - NVIDIA-AI-IOT/yolo_deepstream: yolo model qat and deploy with deepstream&tensorrt + deepstream_yolov4.tgz - Google Drive
YoloV4+dspreprocess : deepstream_yolov4_with_nvdspreprocess.tgz - Google Drive
YoloV5 + nvinfer : GitHub - beyondli/Yolo_on_Jetson
Yolov5-small : Custom Yolov5 on Deepstream 6.0 (Thanks @raghavendra.ramya)
YoloV5+Triton : Triton Inference through docker - #7 by mchi
YoloV5_gpu_optimization: GitHub - NVIDIA-AI-IOT/yolov5_gpu_optimization: This repository provides YOLOV5 GPU optimization sample
YoloV7: GitHub - NVIDIA-AI-IOT/yolo_deepstream: yolo model qat and deploy with deepstream&tensorrt
YoloV7+Triton: Deepstream / Triton Server - YOLOv7(Thanks @Levi_Pereira )
YoloV7+nvinfer: Tutorial: How to run YOLOv7 on Deepstream(Thanks @vcmike )
YoloV8+nvinfer: Deploy YOLOv8 on NVIDIA Jetson using TensorRT and DeepStream SDK | Seeed Studio Wiki
19. [DSx_All_App] How to use classification model as pgie?
The input is a blue car picture, we want to get the “blue” label, here is the test command:
blueCar.zip (37.6 KB)
dstest_appsrc_config.txt (3.7 KB)
Secondary_CarColor.zip (8.2 MB)
1. copy Secondary_CarColor model if needed
if there is no Secondary_CarColor directory, execute unzip -o Secondary_CarColor.zip -d /opt/nvidia/deepstream/deepstream/samples/models
2. test
gst-launch-1.0 filesrc location=blueCar.jpg ! jpegdec ! videoconvert ! video/x-raw,format=I420 ! nvvideoconvert ! video/x-raw\(memory:NVMM\),format=NV12 ! mux.sink_0 nvstreammux name=mux batch-size=1 width=1280 height=720 ! nvinfer config-file-path=./dstest_appsrc_config.txt ! nvvideoconvert ! video/x-raw\(memory:NVMM\),format=RGBA ! nvdsosd ! nvvideoconvert ! video/x-raw,format=I420 ! jpegenc ! filesink location=out.jpg
[Access output of Primary Classifier]
[Resnet50 with imagenet dataset image classification using deepstream sdk]
20. How to trouble shoot error cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
CUDA_ERROR_INVALID_GRAPHICS_CONTEXT = 219
This indicates an error with OpenGL or DirectX context.
Make sure you use nvidia X driver.
Please follow this to setup nvidia X server. Chapter 6. Configuring X for the NVIDIA Driver
These are some common problems you may meet associated with the driver. Chapter 8. Common Problems (nvidia.com)
https://forums.developer.nvidia.com/t/issue-runnung-deepstream-app-docker-container-5-0-6-0-in-rtx-3080-and-a5000-laptop/213783
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1 - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
21.[Jetson] TRT version miss match between Deepstream 6.1 docker and device version can be fixed by APT update for Jetpack 5.0.1 DP
1 docker run --rm -it --runtime=nvidia REPOSITORY:TAG
2 remove previous TRT package
  apt-get purge --remove libnvinfer8 libnvinfer-plugin8  libnvinfer-bin python3-libnvinfer
3 apt-get update
4 install TRT 8.4.0.11 package
  apt-get install libnvinfer8 libnvinfer-plugin8  libnvinfer-bin python3-libnvinfer
5 Verify TRT version
  nm -D /usr/lib/aarch64-linux-gnu/libnvinfer.so.8.4.0 |grep version
related topic 218888
22. [Jetson] VIC Configuration failed image scale factor exceeds 16
this issue is a limitation of Jetson VIC processing and can be fixed by modifying configuration, for example:
# model's dimensions: height is 1168, width is 720.
uff-input-dims=3;1168;720;0
#if scaling-compute-hw = VIC, input-object-min-height need to be even and greater than or equal to (model height)/16
input-object-min-height=74
#if scaling-compute-hw = VIC, input-object-min-width need to be even and greater than or equal to( model width)/16
input-object-min-width=46
related topic [VIC Configuration failed image scale factor exceeds 16, use GPU for Transformation - #3 by Amycao]
23.[DSx_All_App] How to change python sample apps from display to output file or fakesink for the users who do not have monitor in their device, the patch is based on test1 sample.
Usage: python3 deepstream_test_1.py <media file or uri> <sink type: 1-filesink; 2-fakesink; 3-display sink>
nvidia@ubuntu:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1$ diff -Naur deepstream_test_1.py.orig deepstream_test_1.py
--- deepstream_test_1.py.orig	2022-08-15 20:12:39.809775283 +0800
+++ deepstream_test_1.py	2022-08-15 22:06:27.052250778 +0800
@@ -123,8 +123,8 @@
 def main(args):
     # Check input arguments
-    if len(args) != 2:
-        sys.stderr.write("usage: %s <media file or uri>\n" % args[0])
+    if len(args) != 3:
+        sys.stderr.write("usage: %s <media file or uri> <sink type: 1-filesink; 2-fakesink; 3-display sink>\n" % args[0])
         sys.exit(1)
     # Standard GStreamer initialization
@@ -179,14 +179,46 @@
     if not nvosd:
         sys.stderr.write(" Unable to create nvosd \n")
-    # Finally render the osd output
-    if is_aarch64():
-        transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
-    print("Creating EGLSink \n")
-    sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
-    if not sink:
-        sys.stderr.write(" Unable to create egl sink \n")
+    if args[2] == '1':
+        nvvidconv1 = Gst.ElementFactory.make ("nvvideoconvert", "nvvid-converter1")
+        if not nvvidconv1:
+            sys.stderr.write("Unable to create nvvidconv1")
+        capfilt = Gst.ElementFactory.make ("capsfilter", "nvvideo-caps")
+        if not capfilt:
+            sys.stderr.write("Unable to create capfilt")
+        caps = Gst.caps_from_string ('video/x-raw(memory:NVMM), format=I420')
+#        feature = gst_caps_features_new ("memory:NVMM", NULL)
+#        gst_caps_set_features (caps, 0, feature)
+        capfilt.set_property('caps', caps)
+        print("Creating nvv4l2h264enc \n")
+        nvh264enc = Gst.ElementFactory.make ("nvv4l2h264enc" ,"nvvideo-h264enc")
+        if not nvh264enc:
+            sys.stderr.write("Unable to create nvh264enc")
+        print("Creating filesink \n")
+        sink = Gst.ElementFactory.make ("filesink", "nvvideo-renderer")
+        sink.set_property('location', './out.h264')
+        if not sink:
+            sys.stderr.write("Unable to create filesink")
+    elif args[2] == '2':
+        print("Creating fakesink \n")
+        sink = Gst.ElementFactory.make ("fakesink", "fake-renderer")
+        if not sink:
+            sys.stderr.write("Unable to create fakesink")
+    elif args[2] == '3':
+        print("Creating EGLSink \n")
+        sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
+        if not sink:
+            sys.stderr.write(" Unable to create egl sink \n")
+        if is_aarch64():
+            transform = Gst.ElementFactory.make("nvegltransform", "nvegl-transform")
+            if not transform:
+                sys.stderr.write(" Unable to create egl transform \n")
     print("Playing file %s " %args[1])
     source.set_property('location', args[1])
@@ -204,9 +236,17 @@
     pipeline.add(pgie)
     pipeline.add(nvvidconv)
     pipeline.add(nvosd)
-    pipeline.add(sink)
-    if is_aarch64():
-        pipeline.add(transform)
+        pipeline.add(nvvidconv1)
+        pipeline.add(capfilt)
+        pipeline.add(nvh264enc)
+        pipeline.add(sink)
+        if is_aarch64():
+            pipeline.add(transform)
     # we link the elements together
     # file-source -> h264-parser -> nvh264-decoder ->
@@ -225,11 +265,19 @@
     streammux.link(pgie)
     pgie.link(nvvidconv)
     nvvidconv.link(nvosd)
-    if is_aarch64():
-        nvosd.link(transform)
-        transform.link(sink)
-    else:
+        nvosd.link(nvvidconv1)
+        nvvidconv1.link(capfilt)
+        capfilt.link(nvh264enc)
+        nvh264enc.link(sink)
         nvosd.link(sink)
+        if is_aarch64():
+            nvosd.link(transform)
+            transform.link(sink)
+        else:
+            nvosd.link(sink)
     # create an event loop and feed gstreamer bus mesages to it
24. [DeepStream 6.1.1 GA] simple demo for adding dewarper support to deepstream-app
Usege: deepstream-app -c source1_dewarper_test.txt
source1_dewarper_test.txt (3.6 KB)
 .../src/deepstream_config_file_parser.c       |  15 ++-
 .../common/src/deepstream_source_bin.c        |   5 -
 .../common/src/deepstream_streammux.c         |   5 +-
 .../deepstream_app_config_parser.c            |   7 +-
 .../deepstream_app_config_parser_yaml.cpp     |   4 +
diff --git a/apps/deepstream/common/src/deepstream_config_file_parser.c b/apps/deepstream/common/src/deepstream_config_file_parser.c
--- a/apps/deepstream/common/src/deepstream_config_file_parser.c
+++ b/apps/deepstream/common/src/deepstream_config_file_parser.c
@@ -76,6 +76,8 @@ GST_DEBUG_CATEGORY (APP_CFG_PARSER_CAT);
 #define CONFIG_GROUP_STREAMMUX_FRAME_NUM_RESET_ON_STREAM_RESET "frame-num-reset-on-stream-reset"
 #define CONFIG_GROUP_STREAMMUX_FRAME_NUM_RESET_ON_EOS "frame-num-reset-on-eos"
 #define CONFIG_GROUP_STREAMMUX_FRAME_DURATION "frame-duration"
+#define CONFIG_GROUP_STREAMMUX_NUM_SURFACES_PER_FRAME "num-surfaces-per-frame"
 #define CONFIG_GROUP_STREAMMUX_CONFIG_FILE_PATH "config-file"
 #define CONFIG_GROUP_STREAMMUX_SYNC_INPUTS "sync-inputs"
 #define CONFIG_GROUP_STREAMMUX_MAX_LATENCY "max-latency"
@@ -742,6 +744,11 @@ parse_streammux (NvDsStreammuxConfig *config, GKeyFile *key_file, gchar *cfg_fil
           g_key_file_get_boolean(key_file, CONFIG_GROUP_STREAMMUX,
           CONFIG_GROUP_STREAMMUX_ASYNC_PROCESS, &error);
       CHECK_ERROR(error);
+    } else if (!g_strcmp0(*key, CONFIG_GROUP_STREAMMUX_NUM_SURFACES_PER_FRAME)) {
+        config->num_surface_per_frame =
+            g_key_file_get_integer(key_file, CONFIG_GROUP_STREAMMUX,
+            CONFIG_GROUP_STREAMMUX_NUM_SURFACES_PER_FRAME, &error);
+        CHECK_ERROR(error);
     } else {
       NVGSTDS_WARN_MSG_V ("Unknown key '%s' for group [%s]", *key,
           CONFIG_GROUP_STREAMMUX);
@@ -1070,8 +1077,12 @@ parse_dewarper (NvDsDewarperConfig * config, GKeyFile * key_file, gchar *cfg_fil
         g_key_file_get_integer (key_file, CONFIG_GROUP_DEWARPER,
             CONFIG_GROUP_DEWARPER_NUM_SURFACES_PER_FRAME, &error);
       CHECK_ERROR (error);
-    else {
+    } else if (!g_strcmp0 (*key, CONFIG_GROUP_DEWARPER_SOURCE_ID)) {
+      config->source_id =
+          g_key_file_get_integer (key_file, CONFIG_GROUP_DEWARPER,
+          CONFIG_GROUP_DEWARPER_SOURCE_ID, &error);
+      CHECK_ERROR (error);
+    } else {
           CONFIG_GROUP_DEWARPER);
diff --git a/apps/deepstream/common/src/deepstream_source_bin.c b/apps/deepstream/common/src/deepstream_source_bin.c
--- a/apps/deepstream/common/src/deepstream_source_bin.c
+++ b/apps/deepstream/common/src/deepstream_source_bin.c
@@ -1527,11 +1527,6 @@ create_multi_source_bin (guint num_sub_bins, NvDsSourceConfig * configs,
       goto done;
-    if(configs->dewarper_config.enable) {
-        g_object_set(G_OBJECT(bin->sub_bins[i].dewarper_bin.nvdewarper), "source-id",
-                configs[i].source_id, NULL);
     bin->num_bins++;
   NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->streammux, "src");
diff --git a/apps/deepstream/common/src/deepstream_streammux.c b/apps/deepstream/common/src/deepstream_streammux.c
--- a/apps/deepstream/common/src/deepstream_streammux.c
+++ b/apps/deepstream/common/src/deepstream_streammux.c
@@ -92,7 +92,10 @@ set_streammux_properties (NvDsStreammuxConfig *config, GstElement *element)
                config->max_latency, NULL);
   g_object_set (G_OBJECT (element), "frame-num-reset-on-eos",
       config->frame_num_reset_on_eos, NULL);
+  if (config->num_surface_per_frame > 1) {
+      g_object_set (G_OBJECT (element), "num-surfaces-per-frame",
+          config->num_surface_per_frame, NULL);
   ret= TRUE;
   return ret;
diff --git a/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser.c b/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser.c
--- a/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser.c
+++ b/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2018-2021, NVIDIA CORPORATION. All rights reserved.
+ * Copyright (c) 2018-2022, NVIDIA CORPORATION. All rights reserved.
  * Permission is hereby granted, free of charge, to any person obtaining a
  * copy of this software and associated documentation files (the "Software"),
@@ -373,6 +373,11 @@ parse_config_file (NvDsConfig *config, gchar *cfg_file_path)
       parse_err = !parse_osd (&config->osd_config, cfg_file);
+    if (!g_strcmp0 (*group, CONFIG_GROUP_DEWARPER)) {
+      parse_err = !parse_dewarper (&config->multi_source_config[0].dewarper_config,
+          cfg_file, cfg_file_path);
     if (!g_strcmp0 (*group, CONFIG_GROUP_PREPROCESS)) {
         parse_err =
             !parse_preprocess (&config->preprocess_config, cfg_file,
diff --git a/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser_yaml.cpp b/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser_yaml.cpp
--- a/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser_yaml.cpp
+++ b/apps/deepstream/sample_apps/deepstream-app/deepstream_app_config_parser_yaml.cpp
@@ -129,6 +129,7 @@ parse_config_file_yaml (NvDsConfig *config, gchar *cfg_file_path)
   std::string sink_str = "sink";
   std::string sgie_str = "secondary-gie";
   std::string msgcons_str = "message-consumer";
+  std::string dewarper_str = "dewarper";
   config->source_list_enabled = FALSE;
@@ -183,6 +184,9 @@ parse_config_file_yaml (NvDsConfig *config, gchar *cfg_file_path)
     else if (paramKey == "osd") {
       parse_err = !parse_osd_yaml(&config->osd_config, cfg_file_path);
+    else if (paramKey.compare(0, dewarper_str.size(), dewarper_str) == 0) {
+      parse_err = !parse_dewarper_yaml (&config->multi_source_config[0].dewarper_config, cfg_file_path);
     else if (paramKey == "pre-process") {
       parse_err = !parse_preprocess_yaml(&config->preprocess_config, cfg_file_path);
25. [ALL_ALL_nvdsinfer] Add TensorRT Verbose log
To debug nvinfer related issue inside gst-nvinfer, we can enable nvinfer log with setting the enviroment variable “NVDSINFER_LOG_LEVEL”.
The value can be set to following numbers for different level log:
0: NVDSINFER_LOG_ERROR
1: NVDSINFER_LOG_WARNING
2: NVDSINFER_LOG_INFO
3: NVDSINFER_LOG_DEBUG
Example for enabling debug log:
export NVDSINFER_LOG_LEVEL=3
When the NVDSINFER_LOG_LEVEL environment variable is not set, the default log level is error log.
26.[Deepstream6.2 Gst-nvstreammux & Gst-nvstreammux New]How to set parameters reasonably to improve the efficiency of nvstreammux in live mode
Gst-nvstreammux:
  • Set the batch-size to the number of sources
  • export NVSTREAMMUX_ADAPTIVE_BATCHING=yes
  • If you want to get high fps, set the batched-push-timeout to the (1000000 us/maximum fps among the videos)
Gst-nvstreammux New(export USE_NEW_NVSTREAMMUX=yes):
  • Should not turn off the adaptive-batching parameter
  • Please refer to the following basic tuning principles first:Gst-nvstreammux Tuning parameters
  • Set the max-same-source-frames to ceil(maximum fps/minimum fps)
  • Set the max-num-frames-per-batch of each source to ceil(current fps/minimum fps)
Experiment: There are 3 live sources with fps 15, 25 and 30 respectively for runtime source addition/deletion scenarios. We’ll delete the video of 25 fps when the pipeline is running.
Build rtsp server:
  • Install FFmpeg $ sudo apt-get install ffmpeg
  • $docker run --rm -it --network=host aler9/rtsp-simple-server
  • Prepare videos with different frame rates: 15fps.mp4 25fps.mp4 30fps.mp4
  • Open a new terminal and run: $ffmpeg -re -stream_loop -1 -i 15fps.mp4 -c:v copy -an -f rtsp -rtsp_transport tcp rtsp://127.0.0.1:8554/stream0
  • Open a new terminal and run: $ffmpeg -re -stream_loop -1 -i 25fps.mp4 -c:v copy -an -f rtsp -rtsp_transport tcp rtsp://127.0.0.1:8554/stream1
  • Open a new terminal and run: $ffmpeg -re -stream_loop -1 -i 30fps.mp4 -c:v copy -an -f rtsp -rtsp_transport tcp rtsp://127.0.0.1:8554/stream2
Build demo code:
config_mux_source3.txt (2.9 KB)
deepstream_test_rt_src_add_del.c (26.1 KB)
Makefile (2.0 KB)
 $cd /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/
 $git clone https://github.com/NVIDIA-AI-IOT/deepstream_reference_apps.git
 $cd deepstream_reference_apps/runtime_source_add_delete/
Replace files in the directory with attached files
 $cp deepstream_test_rt_src_add_del.c ./deepstream_test_rt_src_add_del.c
 $cp Makefile ./Makefile
 $cp config_mux_source3.txt ./
 $export CUDA_VER=11.8
 $make
Run:
  • ./deepstream-test-rt-src-add-del 0 filesink 1
  • You can add and delete streams by pressing “a” and “d” on the keyboard.
FPS For Streams with Gst-nvstreammux :
  • Set batched-push-timeout to 70000 ms > 1000000 us/ 15fps
    1. Start with all streams
     **PERF: 14.03 (14.95)   25.05 (24.98)   25.05 (24.92)
     **PERF: 15.26 (14.95)   24.42 (24.98)   24.42 (24.92)
     **PERF: 14.71 (14.95)   25.51 (24.98)   25.51 (24.92)
     **PERF: 15.04 (14.95)   25.07 (24.98)   25.07 (24.92)
    1. Delete the stream source of 25 fps
     **PERF: 14.52 (14.96)   16.59 (23.21)   0.00 (19.20)
     **PERF: 15.53 (14.96)   16.66 (23.19)   0.00 (19.13)
     **PERF: 14.73 (14.96)   16.49 (23.17)   0.00 (19.07)
     **PERF: 14.51 (14.96)   16.58 (23.14)   0.00 (19.00)
  • Set batched-push-timeout to 40000 ms = 1000000 us/ 25fps
     **PERF: 15.12 (13.89)   30.24 (28.01)   25.20 (23.92)
     **PERF: 14.94 (13.91)   29.88 (28.03)   24.90 (23.93)
     **PERF: 14.98 (13.91)   29.95 (28.03)   24.32 (23.93)
     **PERF: 15.01 (13.93)   10.32 (27.84)   25.63 (23.95)
     **PERF: 14.47 (14.27)   24.80 (28.13)   0.00 (21.76)
     **PERF: 15.51 (14.28)   24.84 (28.11)   0.00 (21.61)
     **PERF: 14.95 (14.28)   24.92 (28.09)   0.00 (21.46)
     **PERF: 14.83 (14.29)   24.83 (28.07)   0.00 (21.31)
  • Set batched-push-timeout to 20000 ms < 1000000 us/ 30 fps
     **PERF: 15.00 (14.82)   29.58 (36.49)   24.81 (25.10)
     **PERF: 14.94 (14.85)   30.09 (35.51)   25.08 (25.09)
     **PERF: 15.07 (14.88)   30.38 (34.65)   25.14 (24.98)
     **PERF: 15.00 (14.89)   29.54 (34.22)   24.78 (25.07)
     **PERF: 14.97 (14.83)   30.11 (30.67)   0.00 (23.22)
     **PERF: 15.07 (14.83)   30.11 (30.65)   0.00 (22.71)
     **PERF: 14.92 (14.83)   29.71 (30.64)   0.00 (22.21)
     **PERF: 14.95 (14.84)   30.22 (30.62)   0.00 (21.73)
FPS For Streams with Gst-nvstreammux New:
max-num-frames-per-batch: Max number of this stream’s frames allowed to be muxed per output batch buffer
max-same-source-frames: Max number of any stream’s frames allowed to be muxed per output batch
A. Plugin Parameters Settings:
  • max-same-source-frames=1
  • 15 fps video: max-num-frames-per-batch=1
  • 25 fps video: max-num-frames-per-batch=1
  • 30 fps video: max-num-frames-per-batch=1
     **PERF: 15.22 (14.54)   14.00 (14.88)   14.42 (13.84)
     **PERF: 13.89 (14.55)   14.58 (14.86)   14.13 (13.82)
     **PERF: 14.00 (14.54)   14.00 (14.84)   14.42 (13.84)
     **PERF: 15.00 (14.55)   14.59 (14.82)   13.46 (13.85)
     **PERF: 13.46 (14.52)   15.00 (14.81)   0.00 (13.35)
     **PERF: 15.22 (14.51)   14.00 (14.79)   0.00 (13.07)
     **PERF: 13.89 (14.51)   14.58 (14.77)   0.00 (12.80)
     **PERF: 14.00 (14.50)   14.00 (14.75)   0.00 (12.54)
B. Plugin Parameters Settings:
  • max-same-source-frames=2
  • 25 fps video: max-num-frames-per-batch=2
  • 30 fps video: max-num-frames-per-batch=2
     **PERF: 14.79 (14.90)   29.68 (29.84)   25.58 (24.86)
     **PERF: 15.16 (14.90)   30.09 (29.86)   24.32 (24.88)
     **PERF: 14.89 (14.90)   29.87 (29.87)   25.88 (24.90)
     **PERF: 15.09 (14.90)   30.38 (29.87)   24.30 (24.88)
     **PERF: 15.04 (14.94)   30.08 (29.92)   0.00 (17.51)
     **PERF: 14.94 (14.94)   29.86 (29.92)   0.00 (17.32)
     **PERF: 15.00 (14.94)   29.85 (29.92)   0.00 (17.15)
     **PERF: 15.08 (14.95)   30.54 (29.93)   0.00 (16.97)
Deepstream FPS drops when i add more and more RTSP streams
Nvurisrcbin does not reconnect when running multiple RTSP streams
Differences between streammux and new_streammux
RTSP simulator
Different speed of two or more rtsp streams, low frame rate
Batch size adjustment
RTSP & nvstreammux | Frame Stuttering when using sync-inputs=1
Deepstream_parallel_inference_app add rtsp reconnects
If any camera goes down I need to reconnect with out playing the pipeline state playing again
Comparison Between StreamMux and New StreamMux: Which is More Performant for Multi-Stream Live Camera Inputs?
DeepStream Pipeline Camera Sync Issue After Prolonged Running
Rtsp out delay and ouput stream frames order has a bit messy
Deepstream-parallel-infer-app:when one of the stream is disconnected, the stored video and image are inconsistent
Pixel distortions when the pipeline's FPS falls below the frame rate of the RTSP sources
"Input buffer is not NvBufSurface" deepstream failure on camera re-connect
How to get the videos/streams timestamp
Reconnection Issue
Can nvarguscamerasrc and RTSP sources work together in DeepStream?
Latency Issue in DeepStream 6.3 when doing batched inference
Issue with FPS Synchronization in DeepStream 6.3 Handling 2 RTSP Streams
Long Delay (≈7s) When Dynamically Adding Streams with nvmultiurisrcbin in DeepStream
Pipline Warning: gst-core-error-quark: A lot of buffers are being dropped. (13): gstbasesink.c(3003): gst_base_sink_is_too_late ():
Frame Drop and Latency Issues in DeepStream GStreamer Pipeline
RTSP frame extraction problem in deepstream
How to test the pipeline latency of deepstream test3?
New streammux doesnt work with 2 channels
Reconnection Issue
Deepstream with RTSP vs files
Object of type 'GstNvStreamMux' does not have property 'width'
Dynamic Add/Remove Stream Issues with DeepStream nvmultiurisrcbin and nvstreammux
Low FPS for pruned tao toolkit models on deepstream
Getting EOS right after pipeline starts. But only for some cameras
Nvstreammux dropping late buffer
How to calculate batched_push_timeout value?
Multiurisrcbin element issues with remove/add functionality
RTSP doesn't reconnect
Deepstream with RTSP Cameras
Artifacts in RTSP Stream with nvurisrcbin in DeepStreamSDK 7.0
RTSP stream delay in deepstream-app
Multisession inference, segmentation
Perda de pacotes/Problema de decodificação de video
DeepStream Parallel Pipeline and Frame Synchronization
Adding videorate to source bin
The output video file appears fast forward when the pipeline is under heavy load
FPS drop in deepstream pipeline during input stream downtime
Info regarding the `new-streammux`'s ability to dynamically add/delete sources
DeepStream 6.4 Aborted (core dumped)
Pulling hundreds of monitoring channels at the same time, the output results do not match
The deepstream-server use rest api after adding streaming I find the deepstream-server not to infer
DeepStream Detections Out Of Sync With Encoded JPEG Frames For 15+ Video Sources
NVStreammux Settings to Guarantee Synchronization and Full Batches
Warning: gst-resource-error-quark: Could not read from resource
RTSP stream premature ending in multistream pipeline
Multi rtsp in and multi rtsp out
How to calculate and reduce the Gst-uridecode and Gst-nvstreammux plugin time?
Deep stream cpp increasing latency when using 2 cameras
No frames send from rtsp server to deepstream_test3
Cannot introduce a delay in a deepstream pipeline - pipeline stalls when adding "min-threshold-buffers=5" to a queue
Latency and video artifacts in multiple RTSP I/O
Nvcompositor slow
Pixel distortion in multiple RTSP sources with different frame rate using New Streammux
Stream Performance Drops When Number of Streams Less than Batch Size
Deepstream 6.3 deepstream-app cannot decode rtsp stream, output is green video?
Parallel Inference App with Multiple RTSP Sources at Different FPS
Performance Discrepancy in DeepStream: Single Pipeline vs. Independent Pipelines for RTSP Streams
Using appsrc and uridecodebin together in a pipeline
Deepstream-parallell-infer-app newstreammux
Artifacts when batching streams with different frame rates
Delay increase in rtsp over time
Pixel distortion in miltiple rtsp input
Value of batched-push-timeout for NVSTREAMMUX with multiple inputs of different fps
Handling RTSP Stream Failures and Auto-Reconnection in DeepStream
High latency in Deepstream pipeline
Streams are adding with delay in Batch Meta by running deepstream-imagedata-multistream
Trying to understand why Streammux and Nvv4l2decoder has higher latency relative to other elements in my pipeline
Deepstream-server FPS Keep Falling After A While
Nvurisrcbin rtsp reconnection now working deepstream 7.1 service maker
4K 60 FPS with Multi-Camera DeepStream Pipeline Bottleneck
Jetson Orin Nano hangs on recording RTSP to video file
Bug Report - Nvstreammux New HLS Playback Speed Issue
What are the detailed specifications of the properties of new nvstreammux configuration file?
Memory leak in nvinferaudio
Nvstreammux frame drops and jitter (24.9 fps) when enabling ntp-sync in rtspsrc
Re-ID vector embedding is incorrect when using new streammuxer
Which DS version for Jetson Orin Nano/Jetpack 5.1.4/L4T 35.6.0?
New Streammux removing and adding same channel, doesnt work
How to Drop Frames to Reduce FPS at the Beginning of DeepStream Pipeline
Reconnection Issue
Deepstream 6.4 and very low FPS
Problem in running Deepstream App
No frames are being processed in pipeline after sometime
DeepStream/GStreamer: One RTSP source’s latency drifts up (others stable) and pipeline crashes after ~7 hours. Decoder set to disable-dpb=true
Can the demux plugin retrieve data from a specified source in the streammux plugin?
How to use enable_perf_measurement=1 using dockerd
Error(406):Not Acceptable in runtime_source_add_delete(RTSP)
What is the best way to migrate from 6.1 to 6.3 Deepstream ? Also Is there any way I can see the compression of each plugin files and code?
New nvstreammux hangs the Pipeline
Deepstream RTSP streams fail over long run periods
DeepStream using nvurisrcbin leads to a decrease in frame rate
My pipeline always alerts that “Decoder is producing too many buffers”
27. [ALL_ALL_common] Historical DeepStream documents and package links
For the users who are still working on old DeepStream versions, the historical DeepStream documents and packages can be found in the following links:
28. [DSx_All_App] How to connect a USB camera in DeepStream?
28.1 Query the device number by the v4l2-ctl tool
E.g.
$ sudo apt install v4l-utils && v4l2-ctl --list-devices
28.2 Query the supported formats and capabilities of the camera by v4l2-ctl tool.
E.g. Query the camera’s formats and capabilities whose device number is 2.
$ v4l2-ctl -d /dev/video2 --list-formats-ext
The information may be displayed in the following format
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
		Interval: Discrete 0.033s (30.000 fps)
		Interval: Discrete 0.042s (24.000 fps)
		Interval: Discrete 0.050s (20.000 fps)
		Interval: Discrete 0.067s (15.000 fps)
		Interval: Discrete 0.100s (10.000 fps)
		Interval: Discrete 0.133s (7.500 fps)
		Interval: Discrete 0.200s (5.000 fps)
[1]: 'H264' (H.264, compressed)
[2]: 'MJPG' (Motion-JPEG, compressed)
28.3 Choose one format and capabilities from the step 2 query results.
The capsfilter after v4l2src is necessary if your camera can output different formats videos or different resolution/framerate videos with the same format. set the corresponding capsfilter properties to let the camera output the chosen format and capabilities. use gst-launch to construct a working pipeline to test the function.
E.g. The following pipeline lets the camera output video at resolution 640x480, format YUY2 , fps30.
$ gst-launch-1.0 v4l2src device=/dev/video2 ! 'video/x-raw, format=YUY2, width=640, height=480, framerate=30/1'  ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! mux.sink_0  nvstreammux name=mux width=1280 height=720 batch-size=1  ! fakesink
28.3.1 If the camera can output compressed video formats such as “MJPG”, “H264”,…etc, and you choose to use the compressed format in the DeepStream(GStreamer) pipeline. You need to add the corresponding video decoder after v4l2src.
E.g. The following pipeline lets the camera output video at resolution 640x480, format jpeg, fps30.
For Jetson
$ gst-launch-1.0 v4l2src device=/dev/video2 ! 'image/jpeg,  width=640, height=480, framerate=30/1' ! nvv4l2decoder mjpeg=true ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! mux.sink_0  nvstreammux name=mux width=1280 height=720 batch-size=1  ! fakesink
For dGPU
$ gst-launch-1.0 v4l2src device=/dev/video2 ! 'image/jpeg,  width=640, height=480, framerate=30/1' ! nvv4l2decoder ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! mux.sink_0  nvstreammux name=mux width=1280 height=720 batch-size=1  ! fakesink
E.g. The following pipeline lets the camera output video at resolution 640x480, format h264, fps30.
$ gst-launch-1.0 v4l2src device=/dev/video2 ! 'video/x-h264, format=avc, width=640, height=480, framerate=30/1' ! nvv4l2decoder ! fakesink
28.3.2 If all formats and capabilities are not supported by nvvideoconvert, there will be a “linking failed” error. you can add a videoconvert before nvvideoconvert to convert the raw data to the format nvvideoconvert can support.
E.g. The following pipeline lets the camera output video at resolution 640x480, format YUY2 , fps30. videoconvert is used to convert YUY2 to NV12 which is supported by nvvideoconvert.
gst-launch-1.0  v4l2src device=/dev/video2 ! 'video/x-raw, format=YUY2, width=640, height=480, framerate=30/1' ! videoconvert ! 'video/x-raw, format=NV12' ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12'  ! fakesink
28.3.3 using uridecodebin to connect the camera.
uridecodebin is a Gstreamer bin including v4l2src and decoder. Capsfilter can’t be added manually after v4l2src, so the negotiated format and capabilities are unpredictable. we only recommend using v4l2src to connect USB cameras.
E.g. The following pipeline uses uridecodebin to connect the camera, the camera 's output format and capabilities are unknown.
gst-launch-1.0 uridecodebin uri=v4l2:///dev/video2 ! nvvideoconvert ! 'video/x-raw(memory:NVMM),format=NV12' ! mux.sink_0 nvstreammux name=mux width=1280 height=720 batch-size=1 ! fakesink
Streaming stopped, reason not-negotiated (-4)
USB MJPG Camera Not working: streaming stopped, reason not-negotiated (-4)
How to Improve Performance of Semantic Segmentation on Jetson
Deepstream_test_1_usb with CSI camera on jetson orin nano
Setup nvconv dynamically for USB web camera
GStreamer pipeline occasionally fails with "Stream format not found, dropping the frame"
DeepStream-Dewarp app usage with live cam
Can nvurisrcbin be used for opening USB cameras?
Bodyposenet I want to start with usb camera video 0
I refer to the code of deepstream-app, and implemented it, can open the USB camera, but it is very stuck
V4l2src & nvvideoconvert connection issue
Can you please provide sample C/C++ code for CSI/MIPI based Camera using Deep stream
[GStreamer] Unable to convert 16-bit thermal to 8-bit
Deepstream Python app without monitor for edge computing
How to deploy Gazenet using Deepstream-TAO?
DS6.2 dGPU nvv4l2decoder issue
Pixel and green screen when I encode with nvv4l2h264enc plugin
I want to display DeepStream output in a GUI framework
Nvv4l2decoder MJPEG wrong colors
Deepstream python code - Failed in mem copy (Segmentation fault)
Issue with nv4l2src Slow Performance Compared to Filesrc
Usb camera fail on deepstream
[DEEPSTREAM] nvds_obj_enc_process Segmentation Fault on Yolo and Jetson nano
App Run Fails With Errors
Some portion of the frame is located another side
Does not show the camera
外接usb3.0 camera编码延迟较大,2560*1920一帧编码延迟为50ms左右
Error: gst-resource-error-quark: Failed to allocate a buffer
Segmentation Fault When Running Heartrate App
How to output DeepStream pipeline to HLS (hlssink) on Jetson Nano?
DeepStream stopped working after several seconds while using webcam
Deepstream-test5 for usb camera fail
Configuring v4l2 source parameters in deepstream-app
Improving image quality of IMX219
TensorRT and DeepStream 7.1 running problems on USB Camera
IN Deepstream-6.1.1 While re-connect the camera I am getting this error
Running the sample deepstream-test1-usbcam app
Deepstream three v4l2src cameras
How to change the stream source width and height?
Multiple CSI Cameras with Deepstream Python
PERF issues with DeepStream 6.3, YOLOv8l in Jetson Orin Nano
How to add a v4l2 source?
Gstreamer ffmpeg Plugin Install Fail
Testing usb cam on deepstream test1 usb-cam app without pgie config file
Deploy Deepstream 7.0 with USB Camera
Buffer transition error while using nvv4l2camerasrc and nvvideoconvert
ERROR from src_elem: Internal data stream error while trying to connect USB camera to do detection
Modified deepstream-test1 to use a GMSL camera to display a green screen and could not display it properly
29.[DSx_All_App] Debug Tips for DeepStream Nvinferserver Accuracy Issue
This corresponds to the Debug Tips for DeepStream Accuracy Issue and teaches you how to set relevant parameters in nvinferserver.
29.1 Input scale & offset
infer_config {
   preprocess {
     normalize {
        scale_factor: 0.0039215697906911373
        channel_offsets: [0, 0, 0]
29.2 Input Order
infer_config {
  preprocess {
    tensor_order: TENSOR_ORDER_LINEAR
    network_format: IMAGE_FORMAT_RGB
29.3 Dims
Each model also needs a specific config.pbtxt file in its subdirectory for nvinferser. We set the imputlayer and outputlayer dims in the file.
input [
    dims: [3, 224, 224]
output [
    dims: [6, 1, 1]
For the nvinferserver config file:
infer_config {
  backend {
    inputs: [ {
      dims: [3, 224, 224]
29.4 scale and padding
infer_config {
  preprocess {
    maintain_aspect_ratio: 1
    symmetric_padding: 1
29.5 inference precision
For the config.pbtxt file:
input [
    data_type: TYPE_FP16
infer_config {
  backend {
    inputs: [ {
29.6 threshold
postprocess {
  detection {
    nms {
      confidence_threshold:0.2
      topk:20
      iou_threshold:0.5
30.[DSx_All_App] How to parse tensor output layers in the customized post-processing for nvinfer and nvinferserver?
In nvinferserver grpc mode, the layers data may reach randomly. We suggest using the following method to parse tensor output layers.
bool NvDsInferParseCustom(std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
NvDsInferNetworkInfo  const &networkInfo,
NvDsInferParseDetectionParams const &detectionParams,
std::vector<NvDsInferInstanceMaskInfo> &objectList) {
    auto layerFinder = [&outputLayersInfo](const std::string &name)
        -> const NvDsInferLayerInfo *{
        for (auto &layer : outputLayersInfo) {
            if (layer.layerName && name == layer.layerName) {
                return &layer;
        return nullptr;
    /* take layer names generate_detections and mask_fcn_logits/BiasAdd for example. */
    const NvDsInferLayerInfo *detectionLayer = layerFinder("generate_detections");
    const NvDsInferLayerInfo *maskLayer = layerFinder("mask_fcn_logits/BiasAdd");
    if (!detectionLayer || !maskLayer) {
        std::cerr << "ERROR: some layers missing or unsupported data types "
                << "in output tensors" << std::endl;
        return false;
related topics
[Nvinfer's results are different from nvinferserver]
[Running Yolov5 Model in triton inference server with GRPC mode to work with Deepstream]
31.[DSx_All_App] Use nvurisrcbin plugin to do smart record in Python
31.1 Apply the following patch and rebuild the pyds
diff --git a/bindings/src/bindfunctions.cpp b/bindings/src/bindfunctions.cpp
index eade8d5..7a4b459 100644
--- a/bindings/src/bindfunctions.cpp
+++ b/bindings/src/bindfunctions.cpp
@@ -586,7 +586,7 @@ namespace pydeepstream {
                  std::function<utils::RELEASEFUNC_SIG> const &func) {
                   utils::set_freefunc(meta, func);
-             py::call_guard<py::gil_scoped_release>(),
+              py::call_guard<py::gil_scoped_release>(),
               "meta"_a,
               "func"_a,
               pydsdoc::methodsDoc::user_releasefunc);
@@ -601,10 +601,9 @@ namespace pydeepstream {
         // Required for backward compatibility
         m.def("unset_callback_funcs",
-            utils::release_all_func();
+                  utils::release_all_func();
+              py::call_guard<py::gil_scoped_release>());
         m.def("alloc_char_buffer",
               [](size_t size) {
@@ -650,6 +649,14 @@ namespace pydeepstream {
               py::return_value_policy::reference,
               pydsdoc::methodsDoc::get_ptr);
+        m.def("get_native_ptr",
+              [](size_t ptr) {
+                  return (gpointer) ptr;
+              "ptr"_a,
+              py::return_value_policy::reference,
+              pydsdoc::methodsDoc::get_ptr);
         m.def("strdup",
               [](size_t ptr) -> size_t {
                   char *str = (char *) ptr;
diff --git a/bindings/src/utils.cpp b/bindings/src/utils.cpp
index 9f97794..009314a 100644
--- a/bindings/src/utils.cpp
+++ b/bindings/src/utils.cpp
@@ -28,6 +28,7 @@
 #include "nvdsmeta_schema.h"
 #include "utils.hpp"
 #include "nvds_obj_encode.h"
+#include "gst-nvdssr.h"
 #include "bind_string_property_definitions.h"
 #include "../../docstrings/utilsdoc.h"
@@ -103,6 +104,48 @@ namespace pydeepstream {
                      pydsdoc::utilsdoc::NvDsObjEncUsrArgsDoc::cast);
+        py::enum_<NvDsSRContainerType>(m, "NvDsSRContainerType")
+                .value("NVDSSR_CONTAINER_MP4", NVDSSR_CONTAINER_MP4)
+                .value("NVDSSR_CONTAINER_MKV", NVDSSR_CONTAINER_MKV)
+                .export_values();
+        py::class_<NvDsSRRecordingInfo>(m, "NvDsSRRecordingInfo")
+                .def(py::init<>())
+                .def_property("filename", STRING_FREE_EXISTING(NvDsSRRecordingInfo, filename))
+                .def_property("dirpath", STRING_FREE_EXISTING(NvDsSRRecordingInfo, dirpath))
+                .def_readwrite("duration", &NvDsSRRecordingInfo::duration)
+                .def_readwrite("containerType", &NvDsSRRecordingInfo::containerType)
+                .def_readwrite("width", &NvDsSRRecordingInfo::width)
+                .def_readwrite("height", &NvDsSRRecordingInfo::height)
+                .def_readwrite("containsVideo", &NvDsSRRecordingInfo::containsVideo)
+                .def_readwrite("channels", &NvDsSRRecordingInfo::channels)
+                .def_readwrite("samplingRate", &NvDsSRRecordingInfo::samplingRate)
+                .def_readwrite("containsAudio", &NvDsSRRecordingInfo::containsAudio)
+                .def("cast", [](size_t data) {
+                        return (NvDsSRRecordingInfo *) data;
+                     py::return_value_policy::reference)
+                .def("cast", [](void* data) {
+                     py::return_value_policy::reference);
+        struct SRUserContext {
+            int sessionid;
+            char name[32];
+        py::class_<SRUserContext>(m, "SRUserContext")
+                .def_readwrite("sessionid", &SRUserContext::sessionid)
+                .def_property("name", STRING_CHAR_ARRAY(SRUserContext, name))
+                        return (SRUserContext *) data;
31.2 Build and reinstall the pyds-xxxx-py3-none-linux_xxxx.whl
# Please make sure you have compiled and installed pyds correctly.
# If the directory does not exist, please refer to sources/deepstream_python_apps/apps/README
cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
# rebuild the pyds whl
make
# uninstall old version
pip uninstall pyds
# Reinstall the modified version
pip install ./pyds-xxxx-py3-none-linux_xxxx.whl
31.3 Sample code based on deeptream-test1.py
The nvurisrcbin plugin wraps the smart recording feature.
diff --git a/apps/deepstream-test1/deepstream_test_1.py b/apps/deepstream-test1/deepstream_test_1.py
index 1367fb4..ff913fe 100755
--- a/apps/deepstream-test1/deepstream_test_1.py
+++ b/apps/deepstream-test1/deepstream_test_1.py
@@ -25,6 +25,7 @@ gi.require_version('Gst', '1.0')
 from gi.repository import GLib, Gst
 from common.platform_info import PlatformInfo
 from common.bus_call import bus_call
+import ctypes
 import pyds
@@ -110,15 +111,62 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
         # set(red, green, blue, alpha); set to Black
         py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
         # Using pyds.get_string() to get display_text as string
-        print(pyds.get_string(py_nvosd_text_params.display_text))
+        # print(pyds.get_string(py_nvosd_text_params.display_text))
         pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
         try:
             l_frame=l_frame.next
         except StopIteration:
             break
     return Gst.PadProbeReturn.OK
+nvurisrcbin = None
+def stop_record_callback():
+    global nvurisrcbin
+    nvurisrcbin.emit('stop-sr', 0)
+# keep same as native for get size of native struct
+class SRUserContext(ctypes.Structure):
+    _fields_ = [
+        ("sessionid", ctypes.c_int),
+        ("name", ctypes.c_char * 32)
+# GstElement * src, NvDsSRRecordingInfo* recordingInfo, void* data, void* user_data
+def record_done(nvurisrcbin, recordingInfo, user_ctx, user_data):
+    print('******sr done*****')
+    print(f"record_done nvurisrcbin {nvurisrcbin} recordingInfo {recordingInfo}"
+          f" user_ctx {user_ctx} user_data {user_data}")
+    info = pyds.NvDsSRRecordingInfo.cast(hash(recordingInfo))
+    sr = pyds.SRUserContext.cast(hash(user_ctx))
+    print(f"filename {info.filename} -- dir {info.dirpath} {info.width} x {info.height}")
+    print(f"session id {sr.sessionid} -- name {sr.name}")
+def cb_newpad(decodebin, decoder_src_pad, data):
+    print("In cb_newpad\n")
+    caps=decoder_src_pad.get_current_caps()
+    if not caps:
+        caps = decoder_src_pad.query_caps()
+    gststruct=caps.get_structure(0)
+    gstname=gststruct.get_name()
+    source_bin=data
+    features=caps.get_features(0)
+    # Need to check if the pad created by the decodebin is for video and not
+    # audio.
+    print("gstname=",gstname)
+    if(gstname.find("video")!=-1):
+        # Link the decodebin pad only if decodebin has picked nvidia
+        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
+        # NVMM memory features.
+        print("features=",features)
+        if features.contains("memory:NVMM"):
+            # Get the source bin ghost pad
+            sink_pad=source_bin.request_pad_simple("sink_0")
+            ret = decoder_src_pad.link(sink_pad)
+        else:
+            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
 def main(args):
@@ -126,6 +174,7 @@ def main(args):
         sys.exit(1)
+    uri = args[1]
     platform_info = PlatformInfo()
     Gst.init(None)
@@ -138,30 +187,25 @@ def main(args):
     if not pipeline:
         sys.stderr.write(" Unable to create Pipeline \n")
-    # Source element for reading from the file
-    print("Creating Source \n ")
-    source = Gst.ElementFactory.make("filesrc", "file-source")
-    if not source:
-        sys.stderr.write(" Unable to create Source \n")
-    # Since the data format in the input file is elementary h264 stream,
-    # we need a h264parser
-    print("Creating H264Parser \n")
-    h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
-    if not h264parser:
-        sys.stderr.write(" Unable to create h264 parser \n")
-    # Use nvdec_h264 for hardware accelerated decode on GPU
-    print("Creating Decoder \n")
-    decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
-    if not decoder:
-        sys.stderr.write(" Unable to create Nvv4l2 Decoder \n")
+    nvurisrcbin = Gst.ElementFactory.make("nvurisrcbin", "uri-decode-bin")
+    if not nvurisrcbin:
+        sys.stderr.write(" Unable to create nvurisrcbin \n")
+    nvurisrcbin.set_property("smart-record", 2) # enable smart record.
+    nvurisrcbin.set_property("smart-rec-dir-path", ".") # set record path.
     # Create nvstreammux instance to form batches from one or more sources.
     streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
     if not streammux:
         sys.stderr.write(" Unable to create NvStreamMux \n")
+    nvurisrcbin.set_property("uri", uri)
+    # Connect to the "pad-added" signal of the decodebin which generates a
+    # callback once a new pad for raw data has beed created by the decodebin
+    nvurisrcbin.connect("pad-added", cb_newpad, streammux)
+    nvurisrcbin.connect("sr-done", record_done, pipeline)
     # Use nvinfer to run inferencing on decoder's output,
     # behaviour of inferencing is set through config file
     pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
@@ -196,7 +240,6 @@ def main(args):
-    source.set_property('location', args[1])
     if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes': # Only set these properties if not using new gst-nvstreammux
         streammux.set_property('width', 1920)
         streammux.set_property('height', 1080)
@@ -206,9 +249,7 @@ def main(args):
     pgie.set_property('config-file-path', "dstest1_pgie_config.txt")
     print("Adding elements to Pipeline \n")
-    pipeline.add(source)
-    pipeline.add(h264parser)
-    pipeline.add(decoder)
+    pipeline.add(nvurisrcbin)
     pipeline.add(streammux)
     pipeline.add(pgie)
@@ -219,16 +260,7 @@ def main(args):
     # nvinfer -> nvvidconv -> nvosd -> video-renderer
     print("Linking elements in the Pipeline \n")
-    source.link(h264parser)
-    h264parser.link(decoder)
-    sinkpad = streammux.request_pad_simple("sink_0")
-    if not sinkpad:
-        sys.stderr.write(" Unable to get the sink pad of streammux \n")
-    srcpad = decoder.get_static_pad("src")
-    if not srcpad:
-        sys.stderr.write(" Unable to get source pad of decoder \n")
-    srcpad.link(sinkpad)
@@ -252,12 +284,37 @@ def main(args):
     # start play back and listen to events
     print("Starting pipeline \n")
     pipeline.set_state(Gst.State.PLAYING)
+    sessionid = pyds.get_native_ptr(pyds.alloc_buffer(4))
+    print(f"sessionid {sessionid}")
+    sr_user_context_size = ctypes.sizeof(SRUserContext)
+    sr_user_context_buf = pyds.get_native_ptr(pyds.alloc_buffer(sr_user_context_size))
+    sr_user_context = pyds.SRUserContext.cast(sr_user_context_buf)
+    sr_user_context.sessionid = 42
+    sr_user_context.name = "sr-demo"
+    print(f"sr_user_context_buf {sr_user_context_buf}")
+    # signal_info = GObject.signal_query('start-sr', nvurisrcbin)
+    # print(f"signal_info {signal_info.param_types}")
+    # stop smart record manually, optional
+    # GLib.timeout_add(5000, stop_record_callback)
+    def start_sr_function():
+        nvurisrcbin.emit('start-sr', sessionid, 2, 5, sr_user_context_buf)
+        print('******start sr*****')
+        return True
+    timer_id = GLib.timeout_add_seconds(10, start_sr_function)
     try:
         loop.run()
     except:
         pass
     # cleanup
     pipeline.set_state(Gst.State.NULL)
+    # release native memory
+    pyds.free_gbuffer(sessionid)
+    pyds.free_gbuffer(sr_user_context_buf)
 if __name__ == '__main__':
     sys.exit(main(sys.argv))
31.4 Below is an explanation of the behavior of the sample code
  1. Set parameters for smart record
    After creating the nvurisrcbin element, you need to set smart record parameters before starting pipeline. The
    explanation of the parameters can be found in nvurisrcbin.html.
    # For more parameters, please run gst-inspect-1.0 nvurisrcbin to check.
  2. Send a start record signal
    # The sessionid must be of gpointer type, so it needs to be created using native code(pyds).
    # This value is currently a reserved value and the default is 0.
    # The user context parameter is optional.
    # If not needed, set it to None. Similarly, the type of this parameter is gpointer type and needs to be created
    # using pyds native code. Please refer to the patch above.
    nvurisrcbin.emit('start-sr', sessionid, 2, 7, sr_user_context_buf)
  3. Send a stop record signal(Optional)
    # Currently session id can only be set to 0
  4. Wait the sr-done action (Optional)
    Here is the documentation of NvDsSRRecordingInfo
related topic:
[Smart recording on Azure IOTEDGE]
[Smart record in Python]
[Smart Record in python]
[Using smart-record in python]
32.[DSx_dGPU_App] How to use display window in the docker on Dgpu
Precondition:
1.Make sure that a monitor is connected to your host
2.Make sure that the driver version on the host is consistent with the version required by DeepStream. You can refer to the dGPU model Platform and OS Compatibility to get the matching version information.
Steps:
The below requirements shall be met before starting the docker:
1.Set appropriate value for the DISPLAY variable, you can use the “xdpyinfo | grep display” command on the host to get the id of the display
2.Execute the command: xhost + from the host terminal to allow the docker to launch a display window
Ex:
$ export DISPLAY=:0
$ xhost +
Note:
If you have multiple cards on your host, make sure to set NVIDIA’s card as the default one to use. There are two ways to configure the graphics card.
1.cli command:
$sudo apt install nvidia-settings
$sudo apt install nvidia-prime
$sudo prime-select nvidia
2.You can refer to the link switch-intel-nvidia-graphics-card-ubuntu to switch the card. Please choose the NVIDIA (Performance Mode) as show in the following image.
33.[DSx_Jetson_dGPU_Plugin] Dump the inference Inputs in nvinferserver plugin
Nvinferserver plugin and low level library are open source from DeepStream6.2. Here is a method to dump Inference inputs.
33.1 Make sure nvinferserver low level library can be built successfully.
The code path is /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinferserver. Please refer to readme for how to build.
33.2 Install dependencies.
sudo apt-get update
sudo apt-get install libopencv-dev
33.3 Apply patch and build
Please apply patch infer_preprocess.cpp.diff (2.9 KB) to infer_preprocess.cpp, and apply patch Makefile.diff (154 Bytes) to Makefile. Then use the following command-line to build.
export WITH_OPENCV=1 && make
Please use the following command-line to replace the old library with the new library .
mv /opt/nvidia/deepstream/deepstream/lib/libnvds_infer_server.so /opt/nvidia/deepstream/deepstream/lib/libnvds_infer_server.so_ori
mv libnvds_infer_server.so /opt/nvidia/deepstream/deepstream/lib/libnvds_infer_server.so
After restarting the pipeline, nvinfersever low level library will dump the inference inputs to jpg files.
34.[DS6.4_GLib2.0] How to update the GLib 2.0 manually for DS 6.4
As the Note in Quickstart Guide, there is a bug in glib 2.0-2.72 version which comes with ubuntu22.04 by default. If you want to update yourself, you can follow the following methods.
34.1 Install dependencies
Docker: nvcr.io/nvidia/deepstream:6.4-triton-multiarch
apt-get update && apt-get install -y \
    pkg-config \
    python3-dev \
    libffi-dev \
    libmount-dev \
    ninja-build \
    wget \
    libgirepository1.0-dev
pip3 install packaging
pip3 install meson==1.2.0
34.2 get the GLib 2.0 source code and install
Note: If you are using python, it is recommended to install version 2.79 or later. It will install the corresponding gobject-instropection together.
wget https://github.com/GNOME/glib/archive/refs/tags/2.79.1.tar.gz
tar -xzvf 2.79.1.tar.gz
cd glib-2.79.1/
rm -r subprojects/gvdb
meson build --prefix=/usr
ninja -C build install
ldconfig
34.3 run the test demo
glib_version.py (143 Bytes)
Note: First you need to set the GI_TYPELIB_PATH variables to the the gobject-instropection you just installed.
# x86_64
export GI_TYPELIB_PATH=/usr/lib/x86_64-linux-gnu/girepository-1.0
# Jetson
export GI_TYPELIB_PATH=/usr/lib/aarch64-linux-gnu/girepository-1.0
python3 glib_version.py
Or
pkg-config --modversion glib-2.0
You can get the following output
2 79 1
34.4 Other Tips
After the upgrade is complete, please do not run the following command again, which will cause the glib version to fall back to the default version
apt-get update
apt-get -y install libglib2.0-dev
35.How to add custom metadata in a GStreamer native plugin and access it in Python.
Here is an example based on deepstream-test1.py and dsexample.
35.1. Add custom metadata in the dsexample plugin.
diff --git a/sources/gst-plugins/gst-dsexample/gstdsexample.cpp b/sources/gst-plugins/gst-dsexample/gstdsexample.cpp
index d5399c7..764ec0a 100644
--- a/sources/gst-plugins/gst-dsexample/gstdsexample.cpp
+++ b/sources/gst-plugins/gst-dsexample/gstdsexample.cpp
@@ -318,6 +318,76 @@ gst_dsexample_get_property (GObject * object, guint prop_id,
+#define NVDS_GST_META_DSEXAMPLE (nvds_get_user_meta_type((char *)"NVIDIA.NVDS_GST_META_DSEXAMPLE"))
+typedef struct _DsExampleMeta
+  gchar *timestamp;
+} DsExampleMeta;
+/* gst meta copy function set by user */
+static gpointer dsexample_meta_copy_func(gpointer data, gpointer user_data)
+  NvDsUserMeta *user_meta = (NvDsUserMeta *) data;
+  DsExampleMeta *src_meta = (DsExampleMeta *)user_meta->user_meta_data;
+  DsExampleMeta *dst_meta = (DsExampleMeta*)g_malloc0(sizeof(DsExampleMeta));
+  if (src_meta->timestamp == NULL)
+    g_print("no buffer abort !!!! \n");
+    abort();
+  dst_meta->timestamp = g_strdup(src_meta->timestamp);
+  memcpy(dst_meta, src_meta, sizeof(DsExampleMeta));
+  return (gpointer)dst_meta;
+/* gst meta release function set by user */
+static void dsexample_meta_release_func(gpointer data, gpointer user_data)
+  DsExampleMeta *meta = (DsExampleMeta *)user_meta->user_meta_data;
+  if (meta) {
+    if (meta->timestamp) {
+      g_free(meta->timestamp);
+      meta->timestamp = NULL;
+    g_free(meta);
+    meta = NULL;
+  user_meta->user_meta_data = NULL;
+void attach_frame_custom_metadata (NvDsBatchMeta *batch_meta, NvDsFrameMeta *frame_meta)
+  DsExampleMeta *meta = (DsExampleMeta *)g_malloc0(sizeof(DsExampleMeta));
+  if (meta == NULL)
+    abort();
+  struct timeval time;
+  gettimeofday(&time, NULL);
+  double cur = (time.tv_sec) * 1000.0;
+  cur += (time.tv_usec) / 1000.0;
+  /* Add dummy metadata */
+  meta->timestamp = (gchar *)g_malloc0(128);
+  snprintf(meta->timestamp, 128, "cur %.3f ms", cur);
+            nvds_acquire_user_meta_from_pool (batch_meta);
+  if (user_meta) {
+    user_meta->user_meta_data = (void *) meta;
+    user_meta->base_meta.meta_type = NVDS_GST_META_DSEXAMPLE;
+    user_meta->base_meta.copy_func =
+        (NvDsMetaCopyFunc) dsexample_meta_copy_func;
+    user_meta->base_meta.release_func =
+        (NvDsMetaReleaseFunc) dsexample_meta_release_func;
+    nvds_add_user_meta_to_frame (frame_meta, user_meta);
+  g_print("Attached DsExampleMeta from native ==> %s\n", meta->timestamp);
  * Initialize all resources and start the output thread
@@ -759,6 +829,7 @@ gst_dsexample_transform_ip (GstBaseTransform * btrans, GstBuffer * inbuf)
 #endif
       /* Attach the metadata for the full frame */
       attach_metadata_full_frame (dsexample, frame_meta, scale_ratio, output, i);
+      attach_frame_custom_metadata(batch_meta, frame_meta);
       i++;
       free (output);
35.2. Modify the corresponding Python bindings.
diff --git a/bindings/src/bindnvdsmeta.cpp b/bindings/src/bindnvdsmeta.cpp
index 95b0585..2aec39f 100644
--- a/bindings/src/bindnvdsmeta.cpp
+++ b/bindings/src/bindnvdsmeta.cpp
@@ -22,6 +22,13 @@
 namespace py = pybind11;
+  gchar *timestamp;
+} DsExampleMeta;
     void bindnvdsmeta(py::module &m) {
@@ -77,8 +84,25 @@ namespace pydeepstream {
                        pydsdoc::nvmeta::MetaTypeDoc::NVDS_START_USER_META)
                 .value("NVDS_FORCE32_META", NVDS_FORCE32_META,
                        pydsdoc::nvmeta::MetaTypeDoc::NVDS_FORCE32_META)
+                .value("NVDS_GST_META_DSEXAMPLE", NVDS_GST_META_DSEXAMPLE)
                 .export_values();
+        py::class_<DsExampleMeta>(m, "DsExampleMeta")
+                .def_property("timestamp",
+                              STRING_PROPERTY(DsExampleMeta,
+                                              timestamp))
+                .def("cast",
+                     [](void *data) {
+                         return (DsExampleMeta *) data;
+                .def("cast",
+                     [](size_t data) {
         py::class_<NvDsComp_BboxInfo>(m, "NvDsComp_BboxInfo",
                                       pydsdoc::nvmeta::NvDsComp_BboxInfoDoc::descr)
35.3.Access the custom metadata in Python code.
index 861cefc..a3e2809 100755
@@ -47,6 +47,7 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
     # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
     # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
     batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
     l_frame = batch_meta.frame_meta_list
     while l_frame is not None:
         try:
@@ -82,6 +83,19 @@ def osd_sink_pad_buffer_probe(pad,info,u_data):
                 break
+        l_user=frame_meta.frame_user_meta_list
+        while l_user is not None:
+            try:
+                user_meta = pyds.NvDsUserMeta.cast(l_user.data)
+                if (user_meta and user_meta.base_meta.meta_type == pyds.NvDsMetaType.NVDS_GST_META_DSEXAMPLE):
+                    dsexample_meta = pyds.DsExampleMeta.cast(user_meta.user_meta_data)
+                    print(f"access dsmeta from python {pyds.get_string(dsexample_meta.timestamp)}")
+            except StopIteration:
+                break
+            try:
+                l_user=l_user.next
+                break
         # Acquiring a display meta object. The memory ownership remains in
         # the C code so downstream plugins can still access it. Otherwise
         # the garbage collector will claim it when this probe function exits.
@@ -167,6 +181,10 @@ def main(args):
     if not pgie:
         sys.stderr.write(" Unable to create pgie \n")
+    dsexample = Gst.ElementFactory.make("dsexample", "dsexample")
+    if not dsexample:
+        sys.stderr.write(" Unable to create dsexample \n")
     # Use convertor to convert from NV12 to RGBA as required by nvosd
     nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
     if not nvvidconv:
@@ -186,7 +204,8 @@ def main(args):
             sys.stderr.write(" Unable to create nv3dsink \n")
     else:
+        # sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
+        sink = Gst.ElementFactory.make("fakesink", "nvvideo-renderer")
         if not sink:
@@ -206,6 +225,7 @@ def main(args):
     pipeline.add(pgie)
+    pipeline.add(dsexample)
     pipeline.add(nvosd)
     pipeline.add(sink)
@@ -225,7 +245,8 @@ def main(args):
-    pgie.link(nvvidconv)
+    pgie.link(dsexample)
+    dsexample.link(nvvidconv)
     nvosd.link(sink)
35.4.Recompile and install dsexample and pyds, and then run deepstream_test1.py. You will see the following log in the output
Attached DsExampleMeta from native ==> cur 1712056757649.727 ms
access dsmeta from python cur 1712056757649.727 ms
Frame Number=303 Number of Objects=31 Vehicle_count=26 Person_count=5
Attached DsExampleMeta from native ==> cur 1712056757651.504 ms
access dsmeta from python cur 1712056757651.504 ms
Frame Number=304 Number of Objects=27 Vehicle_count=22 Person_count=5
Attached DsExampleMeta from native ==> cur 1712056757653.223 ms
access dsmeta from python cur 1712056757653.223 ms
Frame Number=305 Number of Objects=29 Vehicle_count=23 Person_count=6
Attached DsExampleMeta from native ==> cur 1712056757654.953 ms
access dsmeta from python cur 1712056757654.953 ms
Frame Number=306 Number of Objects=29 Vehicle_count=24 Person_count=5
Attached DsExampleMeta from native ==> cur 1712056757656.722 ms
access dsmeta from python cur 1712056757656.722 ms
Frame Number=307 Number of Objects=29 Vehicle_count=25 Person_count=4
Attached DsExampleMeta from native ==> cur 1712056757658.446 ms
access dsmeta from python cur 1712056757658.446 ms
36.[DSx_All_App] How to use Nsight System CLI to profile DeepStream App from the command line.
Deepstream Plugins that can be queried using this tool.
Plugins Tags
nvv4l2-decoder Call to NV12_to_NV12_cutex Call to cudaEventCreateWithFlags ……
nvstreammux stream-muxer_acquireBufferFromPool(Batch=0) stream-muxer_collectingBuffers(Batch=0) …
nvinfer buffer_process batch_num=1 ……
nvinferserver buffer_process batch_num=1 …
nvdewarper nvdewarper0_(Frame=1)_Scale ……
nvdsosd nv-onscreendisplay_(Frame=0) …
nvmultistreamtiler tiled_display_tiler_(Frame=0) ……
nvtracker (null)_nvtracker_convert_buffer(Frame=0) ……
How to use the tool(Take the deepstream-test1 as an example.)
  1. Make sure you have the Nsight System installed on your system. You can download and install it from the following page Nsight Systems - Get Started | NVIDIA Developer according to your platform.
  2. Use NVTX to trace any CUDA kernal function wrote by yourself if necessary.
  • Add #include “nvtx3/nvToolsExt.h” in the source code.
  • Add the compiler flag “-ldl” in the Makefile
  • Add calls to the NVTX API functions below.
nvtxRangePush("my_cuda_kernal");
//your code
nvtxRangePop();
  1. Run the command below, it will generate a report file called nsys_report.nsys-rep
$nsys profile -w true -t "cuda,cudnn,osrt,nvtx" -o ./nsys_report --cuda-memory-usage=true ./deepstream-test1-app dstest1_config.yml
  1. Use the Nsight Systems App to read the nsys_report on your Microsoft System. As the image below, just right click the GstNvinfer and choose the “Show in Events View”, the detailed information is displayed at the bottom.
